Do they make a bigger scoop ??
Alan8n
11-05-2007 07:23:38
Just finished moving a tandem truck load of fill about 1500 feet with my Jubilee and 30" scoop. Took about 10 straight hours with a 1 hr lunch break.
Looked forward to getting some seat time in the nicest time of the year.
Good things: Tractor ran great. Loading/unloading the scoop was easier then I thought.
Didn't have to hire a backhoe.
Got plenty of seat time.
Bad things:
This morning every bone/muscle in my body hurts
Thought I was in shape ??
Since I probably have to do this once or twice more the question is:
Do they make a bigger earth moving implement ??
Alan
HCooke
11-05-2007 15:16:59
 Re: Do they make a bigger scoop ?? in reply to Alan8n, 11-05-2007 07:23:38
Maybe you could use a 5' box blade to drag the material where you sant it to go?
JMOR
11-05-2007 12:00:41
 six foot wide Re: Do they make a bigger scoop ?? in reply to Alan8n, 11-05-2007 07:23:38
third party image
Never say never.
Link
soundguy
11-05-2007 11:24:21
Yep.. as others siad.. 30" is it.. or get a laoder..
Soundguy
KCM
11-05-2007 10:56:44
What you need is an Overland Scraper (see link). They were designed to move a yard and a half at one time, and were great for digging trenches or leveling ground. They were designed for the Ford tractor and designed to utilize the three-point system.
Of course, unless you plan to use it often, it probably wouldn't pay for itself.
Dave H
11-05-2007 09:58:22
Alan
I found I can drag a lot more dirt around in the 6 ft box blade thatn using the FEL on my 420 JD - a lot more if it is a short drag and it doesen't matter what is in between the load and drop off point.
So if ya got one or could borrow one that may work, I loan mine out to people who take care of it, but the distance to central IL is a little steep.
GB in MT.
11-05-2007 07:45:21
 Re: Do they make a bigger scoop ?? in reply to old, 11-05-2007 07:23:38
Alan; As far as I know; a 30" rear scoop is as big as they get. Next step is, buy a front end loader.
Sounds like you may have had the material piled in maybe two piles.!!???
Next time get the driver to spread the material down your driveway, as they dump. Then you won't have so far to go with each scoop load, and if you have a backblade, you can level out the drive with that.
Just a thought!!!
Garythird party image
Alan8n
11-05-2007 08:40:46
 Re: Do they make a bigger scoop ?? in reply to GB in MT., 11-05-2007 07:45:21
Gary...That would make it easy :)...I am trying to fill in some low spots in my driveway to my cabin..The first part of my "driveway" has a grade to it that the driver thought he didn't want to try...he said he would be able to get it in but was concerned on getting out...
Dell (WA)
11-05-2007 07:44:26
 Re: Do they make a bigger scoop ?? NO!!! in reply to Alan8n, 11-05-2007 07:23:38
Alan..... ...30" wide rear scoop is as big as they make. (altho they do make a 24" scoop") you can't gitt ennythang wider between yer rear wheels.
You need a bigger scoop? RENT a FEL tractor, or HIRE a back-hoe tractor/operator. Simple, eh?..... ..Dell
