Wiring diagram
R.A. George
11-05-2007 13:40:14
Need a wiring diagram for my 9N tractor that I am rebuilding. Can anyone help?
GB in MT.
11-06-2007 05:00:53
 Re: Wiring diagram in reply to Scott PA, 11-05-2007 13:40:14
Bill; That diagram is not one of my making, and to tell ya the truth , I did not even notice the way the light switch was routed. Would tend to rob the coil a little,and maybe shorten the life of the Ign. switch. Altho I have seen a lot of guys using that configuration, so the lights cannot get left on, if the engine is not running.
I just won't use that diagram anymore. It is a shame too, that diagram is so easy to read and is correct in all other ways, as to the stock wiring.
But I'm not going to change someone elses diagram. Maybe you could make one, that you feel would be better. I'm not very good at stuff like that.
Garythird party image
GB in MT.
11-05-2007 14:40:33
 Re: Wiring diagram in reply to Tom N MS, 11-05-2007 13:40:14
when you get to the distrib., This will get ya started until you get your maual.
third party image
That should take care of the wiring.
If you have more questions, post them here and someone will help you.
Welcome to the world of "N"
Gary third party image
R.A. George
11-05-2007 14:19:54
 Re: Wiring diagram in reply to R.A. George, 11-05-2007 13:40:14
Thanks a bunch.... I had forgotten that older Ford's including tractors have a positive ground and I was about to hook it up wrong. Thanks again for both diagrams
GB in MT.
11-05-2007 13:56:46
 Re: Wiring diagram in reply to soundguy, 11-05-2007 13:40:14
Also; if you are rebuilding a 9N, you need to buy a good manual.
The I&T FO-4 Manual is available on this web site under manuals, on the lft. top of this page.
You are going to NEED it.
GB in MT.
11-05-2007 13:50:39
 Re: Wiring diagram in reply to GB in MT., 11-05-2007 13:40:14
Here is one .
third party image
And here is an easier one to read.
third party image
Both of these are stock wiring for 9/2N positive ground.
HTH
BillM (OH)
11-05-2007 21:09:35
 Re: Wiring diagram in reply to GB in MT., 11-05-2007 13:50:39
GB - Could we not move that light switch connection to the terminal block connection so's it doesn't have to go thru the ignition switch? This diagram keeps coming up and is not recommended, The top one is correct.
