Order Ford 8N Parts Online
8n start up after rebuild
ricko700
11-08-2007 19:46:19
Well I got Petunia rebuilt and started up and all the major bugs out so far but I have what appears to be a valve cover leak on the forward cover..(I at first thought it was the bottom of thr fuel pump boss but I see clearly now that the oil is slightly discolored)..is it pretty easy to overtighten them and cause them to leak?/ Is there a torque spec for that one bolt? Its so nice to see her running again ..without smoking up the neighborhood...but all the skeeters were kept away.
Dunk
11-08-2007 20:07:34
 Re: 8n start up after rebuild in reply to ricko700, 11-08-2007 19:46:19
I think so.
Dunk
11-08-2007 19:51:33
Personally I use silicone on those cork gaskets.
And dont think you need to torque em down.
ricko700
11-08-2007 20:02:09
 Re: 8n start up after rebuild in reply to Dunk, 11-08-2007 19:51:33
Ok so just hand tight and a smidge? I have some napa black gasket goop ..will that work ok..I put a little on when I installed them just to hold them in place.
soundguy
11-08-2007 20:17:10
 Re: 8n start up after rebuild in reply to ricko700, 11-08-2007 20:02:09
Pull it off.. clean the area up nd goop it good.. reinstall.. don't hafta torque it down.. too tight ant it will deforem the cover or gasket anyway..
soundguy
