Changing Head Bolts
AlNag
11-11-2007 11:55:30
I have two questions. If I change head bolts without removing the head, should I drain some of the coolant first. Second, will I be able to use a head bolt that is 2-1/2" long?
Dan
11-11-2007 12:02:54
 Re: Changing Head Bolts in reply to AlNag, 11-11-2007 11:55:30
Yes, and yes.
Dan
AlNag
11-11-2007 12:08:44
 Re: Changing Head Bolts in reply to Dan, 11-11-2007 12:02:54
Thanks a lot. Now if I am lucky enough to get the studs out.
Dan
11-11-2007 12:14:46
 Re: Changing Head Bolts in reply to AlNag, 11-11-2007 12:08:44
Now THAT is a challenging prospect :-) I had to get real good at drilling 12 of them out of my 9N block. If you want some real world advice - don't replace those studs unless you absolutely HAVE to.
Good luck,
Dan
AlNag
11-11-2007 12:19:45
 Re: Changing Head Bolts in reply to Dan, 11-11-2007 12:14:46
These shouldn't be a problem because I just had them out when I rebuilt the engine. The problem is that I failed to put a sealant on the threads and the coolant is leaking on the studs.
Den N Ms
11-11-2007 15:21:11
 Re: Changing Head Bolts in reply to AlNag, 11-11-2007 12:19:45
AINag,If its just leaking around the stud threads,and you've had them out .Why don't you drain the block, take them back out one at a time.Put some liquid teflon sealer on them and put the studs back in and retorque the nuts.Fill the radiator back up after running it 30 minutes to a hour. Then retorque them all.The studs will hold better than bolts will.
AlNag
11-11-2007 19:20:42
 Re: Changing Head Bolts in reply to Den N Ms, 11-11-2007 15:21:11
Why would the studs stay tighter than head bolts? They have the same threads into the block and the cap screws are tightened with more torque.
Bob
11-11-2007 21:33:04
 Re: Changing Head Bolts in reply to AlNag, 11-11-2007 19:20:42
Studs avoid the bolts wearing and trying to tear the threads out of the cast iron block everytime the head is tightened.
You doubt studs are BETTER? Ever wonder why performance engine builders replace pretty much ALL critical bolts in the engine with STUDS?
