leaky wech plug remedy follow up
ricko700
11-15-2007 15:33:50
That 7/8" compression plug I got at napa worked great...drove Petunia around the neighborhood and skeert the crap outta all the city punk rocker kids for about an hour and no leaky ...yet...there. Now my main water drain under the oil filter leaks abit...never shoulda cleaned all the rust and dirt outta her..it stopped up all the leaks. Heres a pic...I hope.
Sean (TX)
11-15-2007 15:33:52
 Re: leaky wech plug remedy follow up in reply to ricko700, 11-15-2007 15:33:50
No luck with a regular freeze plug? Must have missed that post. Replaced that same plug a year ago. You have to whack them pretty good...
ricko700
11-15-2007 15:45:36
 Re: leaky wech plug remedy follow up in reply to Sean (TX), 11-15-2007 15:33:52
This one I had to whack again but it quit leaking...the bottom of the other seat is very thin and just doesnt hold...what part of texas er u in?? Im in lewisville.
ricko700
11-15-2007 15:41:15
Better pix
Bob Harvey
11-15-2007 17:18:36
 Re: leaky wech plug remedy follow up in reply to ricko700, 11-15-2007 15:41:15
Great plug. Where did you get it ? You may need the sevices of a GOOD welder person.
ricko700
11-15-2007 17:47:29
 Re: leaky wech plug remedy follow up in reply to Bob Harvey, 11-15-2007 17:18:36
NAPA $3.99...have 3 more for spares just in case...its 7/8"..u need to wet them with wd 40 er spit er something...I used antifreeze since it was all over the floor..and then put a socket on them the same size as the washer and whack it in the hole gingerly and tighten up.
ricko700
11-15-2007 15:38:50
I think part of the seat has corroded away I tried 2 new plugs with no luck.
