Order Ford 8N Parts Online
48 8n still running a little rough
ricko700
11-15-2007 15:59:13
Tried all the carb adjustments that Dell was suggesting and its better but still has some issues...sounds like blub blub blub blub if u say it real fast (lmao) sry ..only way to describe it. Has good power under load in 1-3 gears but 4th is a little boggy on an incline.Seem to have good bright whitish blue sparkies and everythang is new. The carb looks original and Ive never been in it.
old
11-15-2007 17:30:41
 Re: 48 8n still running a little rough in reply to ricko700, 11-15-2007 15:59:13
Take your main jet and with it running slowly open it a little at a time. You should be able to open it up to a point you get black smoke. If you do then turn it back in just till the smoke stops and then take it for a drive. You might be running a little on the lean side and if so that could well be your problem. Of course if you can't get the black smoke you may have a clogged carb main jet
Bob Harvey
11-15-2007 17:16:13
Hmmnnn..... ..... and the sound of rusty gears grinding.
