Sooo, my shift lever rotates......
Cryptkeeper
11-15-2007 16:22:35
What is the best way to replace the pin that keeps the lever from rotating (1940 9N)?
Sorta fun tryin' ta find the gears (takes 2 hands!!)
The notch appears ta be a bit worn as well.
Thx Guys, yer a wealth of knowledge.
Dont let mah name scare ya, I aint the grim reaper.
Ramon
11-16-2007 11:30:34
 Re: Sooo, my shift lever rotates...... in reply to Cryptkeeper, 11-15-2007 16:22:35
What worked for me was to just remove the lever and place it in a vise. Next I would heat AROUND the pin. Generally at that point use a good pair of vise-grips or channel lock pliars to pull the old pin from the lever. Lastly, drop the new pin & let it cool.
Dan
11-15-2007 16:50:43
You have to remove the entire shifter cover to remove this shifter and get that pin out. The previous owner did drill a hole in the shifter collar on the opposite side so they could pound out this pin and replace it without removing the cover - your call. However; if you want to fix the worn area on your shifter collar anyway - bite the bullet and pull the cover.
As Dunk showed you, it is a fixable issue. The biggest challenge is finding a company that welds aluminum (like custom ladder racks and such). Luckily - I live in a big city and the variety is a bit better. Those guys were good and welded mine up in less than 5 minutes - it was the best $25 I have spent in a long time. I can send you the CAD drawings with the proper dimensions to cut the new slot if you do get it welded up.
Good luck,
Dan
Dunk
11-15-2007 16:38:11
Dan would be the X-purt on that.
While we are waiting skim over these 2 topics.
Dunk
11-15-2007 16:38:48
 Re: Sooo, my shift lever rotates...... in reply to Dunk, 11-15-2007 16:38:11
Topic 2
