Order Ford 9N Parts Online
9N throttle Control Lever
Sean (TX)
11-18-2007 08:13:45
How do you go about removing it? I want to remove it and weld the flat spot that rides on the Throttle Quadrant. Then file it round again. Have a new Throttle Quadrant on the way.
Sean (TX)
11-21-2007 16:02:43
 Re: 9N throttle Control Lever in reply to Sean (TX), 11-18-2007 08:13:45
Well got my NOS throttle quadrant off ebay today third party imageJust need to prime and paint....Going to weld the throttle lever and file it round...Is that how they are new? Round that is...
third party image
third party image
Joe T (CO)
11-19-2007 17:48:35
 Re: 9N throttle Control Lever in reply to Ken Crisman, 11-18-2007 08:13:45
Sean (TX) said: (quoted from post at 04:47:49 11/19/07)
Wow...Yours is wore deeper then mine. The steal ball is a good idea. Im debating on welding it to build it up...Then file it round again. Dont really want to remove it..
Yep the guy I bought mine from didnt take care of it. I kick myself for buying it, but I know allot more about 9Ns than I would have..... .5K later
I was much wiser when I bought the 2N, not caring if I got it or not made the deal sweeter.
If I could have got the rivit out I would have replaced the piece..... .
old timer in ohio
11-19-2007 04:50:23
Hey there JMOR;
I once used that same trick,on
an unrepairable,in tank Audi
fuel pump.Saved me $350.00 (for a new one). Bob
God Bless
Sean (TX)
11-19-2007 02:47:49
 Re: 9N throttle Control Lever in reply to Iron Rose Farms, 11-18-2007 08:13:45
Joe T (CO)
11-18-2007 19:51:13
 Re: 9N throttle Control Lever in reply to GB in MT., 11-18-2007 08:13:45
Sean (TX) said: (quoted from post at 10:13:45 11/18/07) How do you go about removing it? I want to remove it and weld the flat spot that rides on the Throttle Quadrant. Then file it round again. Have a new Throttle Quadrant on the way.
Mine was worn pretty bad. I tried removing the rivit but could not get it out. I was worried I would screw it up worse.
I put a drill point the same diameter as the hardened steel ball in the lever. I used JB weld to hold it in and fill up the rest of the worn area. The ball sits just high enough to ratchet on the quadrant now. I also took a dremel to my quadrant and made the lines a little deeper for the ball to catch in.
But as you know I still aint done with the tractor.....
Joe
third party image
Sean (TX)
11-18-2007 17:36:09
 Re: 9N throttle Control Lever in reply to Tom N MS, 11-18-2007 08:13:45
I remember...Old news.. lets drop it....That page is not much good. That is for a 8N...I have a 9N..His 9N link is no good!!
Sean
Hobo,NC
11-18-2007 18:24:56
 Re: 9N throttle Control Lever in reply to Sean (TX), 11-18-2007 17:36:09
Like I said been awhile BUT I remember drill'n out the pin will not for git that part.
JMOR
11-18-2007 17:32:06
Maybe this will be helpful.
P.S. Got your tractor going faster with those small rear tires yet? You remember, just like the motor cycle with the smaller rear sprocket?
Sean (TX)
11-18-2007 09:28:14
 Re: 9N throttle Control Lever in reply to D Squared, 11-18-2007 08:13:45
I thought only the 8N's had a steel ball? I see Dennis carpenter is selling a repro now. Might just get me a new one.Mine Has been stick and was having trouble to get it to low idle. Lubed all the linkage point on the throttle control rods it is working better. Wont stay at full throttle...Starts to creep back twords inle on its own.
third party image
Hobo,NC
11-18-2007 08:57:52
2 git the throttle leaver out theirs a pin/rivet that you will haveta drill out,,, been awhile so dont rightly remember the size. Not sure either if yours has a 3/8" steel ball that runs on the plate,,, Jeb2N got the last one I had,,, I do have a nutter steering column that has been sit'n side my desk for a few years BUT I moved it a few weeks ago to a safe place so safe I kin not lay my hands on it He He.
