Order Ford 8N Parts Online
1952-8n ford serial # 448314
phillip forsyth
11-18-2007 10:06:06
I have no compression on the 1st two cylinders and 100-110 on cyl 3&4. wich engine kit would you recomend? and should I do a complete overhaul or just an in frame? thanks,phil
john hunt
11-19-2007 06:31:23
 Re: 1952-8n ford serial # 448314 in reply to phillip forsythe, 11-18-2007 10:06:06
put transmission fuild in 1,2 cyl and see if it leak down fast, if it leak down in few mintue. I would say yes rebuild.. but if stay up over night.. I would said it valve job, head gasket job. you can do all this in frame
old
11-18-2007 11:59:46
Your probably jumpping the gun on an engine over haul. Most of the time a problem like that is a simple fix. Like the others have said head gasket, stuck valve, weak valve springs etc. Not long ago I had a problem like that on an 8N and it was caused by a broken valve. Replaced the valve and the valve guide and all is well now. Cost me around $50 total to fix the problem and the big cost was the gasket set. I picked up a good used valve and guide for $10. My self I would open up the engine and have a look it could well be a $50 or less fix, unless of course you know for sure that the engine is wore out and even then you need to open it up before buying a kit just so you know what may have been done to in in the past.
Ken(Ark)
11-18-2007 10:28:20
You really need to pull the motor apart before you buy any parts . Like the other guys have said , it might be a stuck valve or bad head gasket and may not need sleeves and rings .
The rod and main bearings may be perfect or wasted . The sleeves may need to be .005 oversized and theres no telling what size the bearings are now .
Bob
11-18-2007 10:20:59
Having NO compression in two adjacent cylinders can be caused by a failed head gasket.
Ken L.
11-18-2007 10:20:37
Pull the front side cover to see if the valves are stuck. If they are ok, I'd pull the head to see if the head gasket is blown between 1&2.
Sean (TX)
11-18-2007 10:07:42
 Re: 1952-8n ford serial # 448314 in reply to Mark Pearce, 11-18-2007 10:06:06
Sounds like stuck valves...See GB in MT's post below.. Link
