You need to check the charging voltage at the battery. You are expecting about 14.5 Volts, or even a little more. It is POSSIBLE the old battery could have been sulfated, or had a shorted cell, making the other cells get overcharged, heating and boiling the battery. On the alternator, the #1 terminal is the "switched excite" terminal, and should only have power when the ignition switch is "ON". If the #1 terminal has power to it with the ignition switch "off", the voltage regulator will keep the alternator's rotating field energized, until the battery is run down. The #2 terminal is "voltage sense", and can be powered at all times. You need an "idiot lamp", a resistor, or a diode in the lead to the #1 terminal to prevent "current backfeeding" and engine run-on when the ignition switch is shut off, as well as to protect the diode trio and voltage regulator inside the alternator. Try disconnecting ONLY the wire from the #1 terminal, and see if your battery drain goes away. If so, you need to make some wiring changes. If NOT, it sounds like the alternator has internal problems, likely a bad diode.
