Oil psi problem
Norm
05-26-1999 17:34:43
bought a 51 8n, when you first start it about 40# psi after 5 min dropes to 5# & stayes there! changed the oil & filter found no oil in the filter canester blew out the oil lines "all clear" new oil filled canester Same thing Were's the problem??? thanks for any info!
E.Allison
05-27-1999 06:29:55
 Re: oil psi problem in reply to Norm, 05-26-1999 17:34:43
As long as you have 5 psi and no knocking sounds I'd leave it alone. 5 psi is enough. EEA
Mike in NC
05-26-1999 21:06:51
Norm:
Based on my own experience with similar oil pressure drop, I would expect a problem with a worn crankshaft and or bearings. Best idea is to pull the crankshaft, take it to a machine shop and have it "miked" and if necessary turned. Oversize main rod bearings are available at a reasonable cost.
Good luck,
Mike
