J D pto
Rodney campbell
11-25-2007 07:19:23
Does a model 70 john deere have two different speeds like 550 and 1000? Just had new pto clutches and disc plates installed in my tractor by a j d dealer. When I started to use it with a brush hog it started to slip in real heavy grass and doesnt seem to be turning fast enough. If you can change speeds how do you do it?
JMOR
11-25-2007 20:02:40
 Re: J D pto in reply to Rodney campbell, 11-25-2007 07:19:23
Over here, most of our motors go put-put-put-put, NOT put-put-notta-notta-notta-put-put.
Sorry, couldn't help myself.
Come on now, fingers....stop that!
Rodney campbell
11-28-2007 06:01:28
 Re: J D pto in reply to JMOR, 11-25-2007 20:02:40
Thanks for the "pearls of wisdom" - TRULY appreciated. Speaking of fingers..... .....
WeirdDeere
11-25-2007 13:05:30
The JD forum is your best bet for answers...
But...STOP running it! Get your PTO clutches adjusted before you burn them up. There's not alot of material there, and it doesn't take long to ruin them. It is slipping, causing your low RPM.
No, you can't change speeds...
There WERE kits for 1000RPM (which are almost NEVER seen), but it is a complete swap, you would only have 1000RPM, and no switching back and forth unless you swapped alot of parts.
Brandon
Jim SC
11-25-2007 08:14:42
JD 70's had only 540 RPM PTO unless you had some modification I haven't heard of before.
GB in MT.
11-25-2007 07:37:01
 Re: J D pto in reply to Bob, 11-25-2007 07:19:23
Rodney; You might want to try posting your ???'s, on the John Deere forum. You will get faster and more informed Info. there.
Go to the "jump to" box at the bottom of this page, then sellect John Deere. That will put ya on the right net, for this kind of info.
HTH
Garythird party image
