Rotor Broke
wayne-t
11-25-2007 16:06:00
Why would it be broke , I just got it and opened the dis... and it was broke, points look good and all the springs (2) of them look ok, cap is not broke and looks new???Any help would be great. Thanks
third party image
36 coupe
11-27-2007 02:45:02
 Re: Rotor Broke in reply to wayne-t, 11-25-2007 16:06:00
Compare the length to the old rotor.Import parts are almost right copies.
wayne-t
11-26-2007 16:22:42
 Re: Rotor Broke in reply to Hobo,NC, 11-25-2007 16:06:00
And the cap looks good on the inside ,,Thanks for all the help, Sorry I did not tell you all that from the start ,,New to this internet thing.
wayne-t
11-26-2007 16:18:47
 Re: Rotor Broke in reply to Dan, 11-25-2007 16:06:00
ok it is a 50-52 8N funked ford it has a flat 6 cylinder,Side mount distubutor
third party image
third party image
gahorN
11-26-2007 15:25:52
What's the inside of the distributor cap look like? Any indication the rotor contacted a terminal inside it?
wayne-t
11-26-2007 11:35:28
 Re: Rotor Broke in reply to Ford 312, 11-25-2007 16:06:00
I checked and the shaft is tight ?? Needs to be clean
(side mount)
third party image
third party image
old
11-26-2007 15:34:16
 Re: Rotor Broke in reply to wayne-t, 11-26-2007 11:35:28
Ok your problem may be that you have the wrong distubutor on the tractor. The one in the pictures shows clearly that its made for a 6 cylinder not a 4 cylinder engine. The pictures show 6 cam lobs not the normal 4 that an N series tractor should have. Also I don't see a spring clip do you have one or is it missing also.
wayne-t
11-25-2007 19:13:39
 Re: Rotor Broke in reply to Jerry9N, 11-25-2007 16:06:00
Ok I will check first thing tomorrow ,,thanks to all that replied!!
old
11-25-2007 18:33:19
What tractor is it on?? Frount or side mount?? If its front mount theres no clip to hold it but it should fit good and tight. If its a side mount it should have a little spring clip to hold it and with out the spring clip it flops around and causes them to brake some times before you even get it started.
Tom N MS
11-25-2007 18:40:21
 Re: Rotor Broke in reply to old, 11-25-2007 18:33:19
From looks of it, don't look like a front mount. Agree?
'taint front mount -- ro
11-26-2007 15:20:43
 Re: Rotor Broke in reply to Tom N MS, 11-25-2007 18:40:21
Judging by the six lobe distributor cam and the seven nipple dist cap and the power wire going through the distributor body -- it is not an 'N tractor front mount. Looks to be for some six cylinder side mount engine.
Roger
old
11-25-2007 18:59:46
Yep I agree but you never know for sure that pictures not all that good.
soundguy
11-25-2007 18:29:35
as the others said.. look for shaft wobble and to make sure the cap goes on correctly.
soundguy
Elmoebutler@locnet.net
11-25-2007 18:02:45
Did you have the little metal clip on the dist. shaft to keep the roror from flopping around?
Tom N MS
11-25-2007 17:01:35
Check for shaft slack/wobble..
