OT - JD garden mower won't restart when hot.
Too Tall
11-26-2007 06:18:38
I’ve got a little JD garden tractor (13hp) that has run great, and has started every time, until recently. Within the past 2-3 weeks, it has started fine, and runs perfect until you shut it down. Once you shut it down, it refuses to restart until it has cooled off for at least 45 minutes. I know this is OT – and I know this has been covered before for the N’s, but I can’t remember what this indicates. I've searched the archives, but can't find anything.
Any help would be appreciated.
Thanks,
TooTall
Too Tall
11-28-2007 07:36:10
 Re: OT - JD garden mower won't restart when hot. in reply to OKDAD, 11-26-2007 06:18:38
Thanks Tex -
I'll check it out
TooTall
Too Tall
11-27-2007 05:04:24
 Re: OT - JD garden mower won't restart when hot. in reply to Dan, 11-26-2007 06:18:38
OK - So I ran it last night for about 30 minutes and tried to restart it. No good. Have fuel. No spark at all. Not even a weak one.
So - Old Texas Boy mentioned a stator? What is this? could this be my problem? I'm not sure how this thing generates a spark?
Thanks for any help,
TooTall
LWD
11-26-2007 23:13:33
 Re: OT - JD garden mower won't restart when hot. in reply to Too Tall, 11-26-2007 06:18:38
I put a cheap electrical fuel pump on my koler, it makes things qucker in cold weather too. and no more vaper lock.
Bob in NC IA
11-26-2007 21:12:17
I have a JD X-485 25 hp garden tractor that I mow with. In Iowa we use a lot of 10% ethanol fuel. When it is hot and you try to restart it, it starts very hard and spits and spudders for a while then smooths out. If I use regular fuel, I have no starting problems at all.
Old Texas boy
11-26-2007 10:09:34
the stators? TH thing that replaces the coil goes south on JOhn Deere yard mowers,, they can bereplaces wiht an electronic device.. Had to do it on one simular to yours some years ago,, never had another issue with it not restarting.
Too Tall
11-26-2007 08:16:07
Old - It will seemingly run for as long as there is fuel in the tank. This past weekend, I had it running for a bit over 3 hours untill I shut it down when I was done. Just for grins I tried to restart it, and of course, it wouldn't. It just kept cranking. Didn't even sound like it was trying to start.
All - Thanks for the ideas. I'll check these out and go from there. Of course I welcome any more suggestions too :-)
Thanks,
Chris
old
11-26-2007 08:03:08
Might be the coil and or a vapor lock. Will it keep running for say 2 hours or will it also die if you run it much longer?? As sound say all engines work the same so trouble shooting one works on the others . Fuel spark and compression timed right and any engine should run at any time. Loose one of those no run
Britcheflee
11-26-2007 07:27:50
 Re: OT - JD garden mower won't restart when hot. in reply to ZANE, 11-26-2007 06:18:38
Does it have an in line fuel filter? Could the filter be blocked a bit causing a reduction in flow of gas and this might lead to an air bubble in the fuel line caused by heat?
It might not be the fact it is cooling off - just the time factor for the fuel to get through?
Lee
soundguy
11-26-2007 07:28:02
Just like with any gas engine, N or otherwise..
When she won't restart.. check for spark a tthe plug.. if you got spark.. check for gas fromt he carb.. If this is a brigs.. it will have a small metal carb bowl.. etc..
If she will 'bang' and start, but then stall on ether.. you have spark.. and a fuel problem..
Soundguy
