2N timing (again)
Mel-N-WV
11-26-2007 09:10:38
I had posted a few days ago about not being able to set the static timing on my 2N. Well, I found something wrong. The plate that is attached to the shaft, the one with the slots for the weight pins to fit in, was loose. I twisted the shaft inside it to my advantage and then used a hammer and punch to try to tighten it up. After I re-assembled the distributor I was able to set the timing.
I know that sooner or later I will probably have to repalce that whole assembly, but this will get me going for now
Thanks to all who posted earlier
Mel
Mel-N-WV
11-28-2007 05:15:58
 Re: 2N timing (again) in reply to Mel-N-WV, 11-26-2007 09:10:38
[quote="Bob"](quoted from post at 18:19:02 11/26/07) Yes you did
third party image.. There is evidence that the distributor has not had the best of care and it has been the source of most the trouble with "Ace" not running well since I have owned him(1999). "Ace" though, like me, is retired. His biggest job is to set in the shed (old garage) and drip oil on the floor. But when I want th use him I expect him to start and run well, so soon I will have to bite the bullet and get a new dist. or at least new guts for the one I have.
Thanks again
Mel
Bob
11-26-2007 14:19:02
TOLD 'YA it was wear in the centrifugal advance mechanism!
Glad to hear you got it repaired.
