3 pt hitch chain harrow assembly.
peevee
11-27-2007 15:48:04
Can someone tell me if my 2N could safely lift an 8 ft wide set up (Delta) with 8 ft long chains? I believe the tractor can lift about 700 lb close to the drawbar, but this set up has a long overhang. The sales people can't tell me the weight, and the website is no help.
Thanks
Peter
'Ol Bob
11-28-2007 09:04:52
 Re: 3 pt hitch chain harrow assembly. in reply to Mark Pearce, 11-27-2007 15:48:04
I've got a '47 8N that I use a 6 ft. chain harrow with 3 point lift on and it handles it fine. The total weight of the harrow and lift is about 400 lbs.
I wouldn't think that the 8 ft. unit is going to be all that much more.
Go fer it but let the clutch out easy third party image
old
11-27-2007 16:49:38
 Re: 3 pt hitch chain harrow assembly. in reply to peevee, 11-27-2007 15:48:04
A good working 3 point on an N will lift up over 800lbs but, and thats the big one. If you load is back a long ways the front becomes very light to the point the front wheels will be in the air and thats not something that is fun to have happen because you can flip it and or loose control and do some funny things
