Touch Control Lever
Sean (TX)
11-28-2007 16:37:48
Are the after market ones different then the originals? Just got mine off today had to soak it with WD40 for a few days.
These holes would have to be rotated 90° to match mine. Should have got a pic...To dark now...
Here is a after market one...
third party image
I think it will be good to go if I can bend it back. Someone bent it so it would rub on metal and stay in the down position... Didnt have a friction disk in it....May have to resort to a torh...BFH is not working so far...
Sean (TX)
11-29-2007 02:33:03
 Re: Touch Control Lever in reply to TimW(PA), 11-28-2007 16:37:48
Thanks ill take a torch to it..Need to weld the area that is about wore through from rubbing..
John (TR)
11-28-2007 19:53:28
 Re: Touch Control Lever in reply to Sean (TX), 11-28-2007 16:37:48
Sean
9/2n levers are different than the 8n levers. You can use the 8n but you need the cast aluminum part that runs against the friction disk. Dont see many arms for 9ns on ebay as I need one also. Have an 8n arm on my 2n right now.
Sean (TX)
11-28-2007 17:20:03
 Re: Touch Control Lever in reply to Mark Pearce, 11-28-2007 16:37:48
Here is a pic..
third party image
Sean (TX)
11-28-2007 17:10:13
 Re: Touch Control Lever in reply to Peter, Covington, LA, 11-28-2007 16:37:48
That thing looks flat...Mine is nowhere near flat...Im starting to wonder if it is off another model tractor...Ill get a pic...
ericlb
11-28-2007 17:02:24
sean you might need to order the control lever plaet that goes with that handel i got the whole set off this site for about 35 dollars but the holes mached up to the old plate i broke too the original ball on the handel is larger but it works fine
Sean (TX)
11-28-2007 16:41:43
 Re: Touch Control Lever in reply to S Russell (TX), 11-28-2007 16:37:48
Forgot to mention it is a 41 9N...
