Locking rear end followup
Nolan
05-27-1999 04:06:39
Well the Detroit style locker will not work with a tractor. Not if I want to turn tight and use wheelbrakes that is.
Spoke to the company, and they can build me one easily enough. Might even have one on the shelf that will fit. But they work by letting the outer wheel in a turn over-run, and powering the inner wheel. That won't work with wheel brakes and tight turns. Oh well, it sounded good.
Kinda surprised that no one apparently made or marketed a locking differential modification for the N. Seems like a rather basic and fundamental item.
Well, it's what neighbors are for anyhow. Helping each other out. I'll do what I can with my N, and call in help when I need it. And do the same for them.
bg
05-27-1999 18:46:31
 Re: Locking rear end followup in reply to Nolan, 05-27-1999 04:06:39
Ockham's Razor cuts again! With the N's low power and light weight, the alternate brake pedal "waddle" is about all you need.
