hot feet
richard alfred
11-30-2007 11:14:19
my tractor is an 8n and where i put my right foot down gets hot enough it was making the rubber on my shoes smell as if it was melting. is there a cover that goes between it and the muffler or what might be the problem. thanks in advance
DJ in Pa.
11-30-2007 13:59:36
 Re: hot feet in reply to richard alfred, 11-30-2007 11:14:19
A piece of aluminum can reflect and dissapate a lot of heat.
Dan
11-30-2007 11:59:43
Look towards the end of the "Restoring" section on the link below and you will see a good shot of the original asbestos lining Ford put there for just that reason.
Dan
LeeMo
11-30-2007 11:17:13
There should be an asbestos pad on the bottom of the floor board to take care of that. I suspect yours is missing.
Angelo Misthos
11-30-2007 11:46:37
 Re: hot feet in reply to LeeMo, 11-30-2007 11:17:13
Lee MO, My 8N bottom of right running board bracket has tiny bits of asbestos still remaining. (I don't know if I'm the environmental polluter or the previous owner was.) Asbestos is hard to get today; I wouldn't want to use it anyway. Would a small sheet of fiberglass or something similar make a good sustitute pad? Anybody can chime in. Thanks. Angelo
soundguy
11-30-2007 20:43:00
 Re: hot feet in reply to Angelo Misthos, 11-30-2007 11:46:37
furnace matting..
soundguy
soundguy
11-30-2007 20:42:55
furnace matting..
soundguy
richard alfred
11-30-2007 11:37:17
now i need to know where to find it. its easier to ask than to go through 100 different web sights
soundguy
11-30-2007 11:47:29
 Re: hot feet in reply to richard alfred, 11-30-2007 11:37:17
Find some furnace matting to put under there...
soundguy
Am-Seb
11-30-2007 12:07:02
 Re: hot feet in reply to soundguy, 11-30-2007 11:47:29
Thanks,Soundguy. I'll use that info, too. Angelo
richard alfred
11-30-2007 11:29:49
thank you for the info and my shoes appreciate it too
