Order Ford 8N Parts Online
8n ford brakes
alan birch
12-01-2007 19:03:57
replaced wheel seals and brake lining and adjusted. when left wheel turns backward wheel locks up and drags.removed wheel many times cant see anything wrong. what night be causing this? one wheel had 2 springs didnot know where it went could this be the problem? thanks smoke.
soundguy
12-01-2007 21:52:18
 Re: 8n ford brakes in reply to alan birch, 12-01-2007 19:03:57
Back your brakes off just a hair.
Did you chamfer the grabbing edge a bit before you installed the shoes?
Soundguy
NJ howie
12-01-2007 20:20:26
it's late and can't remember much[trying to kick the keg] but the left side has more weight,your pedal has to go thru the trans i beleave thats y you have to sprinigs buts it's only on on side. as you adjust your break you can make your pedals even.good luck luck and happy tractoring
Tom N MS
12-01-2007 19:14:45
This might help. Link
