JMOR
12-03-2007 06:53:50
Re: 8N No spark in reply to AJH8Nw, 12-03-2007 06:16:38
No, not distributor. It means you are losing the current (suffering a voltage drop) somewhere up stream of the coil. The places to look as I mentioned before are: resistor, key switch, wire between key & resistor, wire from key sw to solenoid's batt terminal(where everything except starter gets power).See the diagram (green path). Turn on key, rock to get points closed (you did that before) and when voltmeter connected from top of coil to ground shows the 0.25v (if repeatable) or some other low voltage, then start working your way up stream, one step at a time. 1) voltage from resistor output terminal (the one going to coil). If it is vary nearly the same voltage as at coil, then that connection is ok. Next: 2) voltage at input side of resistor (should be very nearly full battery voltage or 6 v (if it is, then we have found a bad resistor or dirty connections to resistor (remove, clean, reconnect, re-measure), If the voltage in step #2 is NOT 6v but something very low, then the problem is further up stream toward the battery ( next step is Key Sw) 3)Key on, measure voltage at output of key sw and at input to key sw...should be very nearly identical at 6v, if not then bad key switch. If you have very low voltage at both in & out of key sw, then look still further upstream. 4) Trace wire from key input 3rd terminal on resistor terminal block, measure voltage, next, ammeter, measure IN & Out ammeter terminals (if no ammeter terminals & wire just passes thru loop on back of ammeter, skip ammeter measurements)then to solenoid battery terminal and measure voltage on that wire terminal, if 6v, then the wire in question or it's terminals are the problem, if still very low voltage at that point, then the only thing left in the path is the battery cable, but since starter motor run, it is not likely. OK, now you should see where the voltage disappears as you traversed the path point by point. In which ever item/component it was lost, temporarily jumper that item & try starting. Items were several wires, resistor, key, terminal block, ammeter, etc.
