Oil in the cooling system
jethro2
12-03-2007 16:01:27
on a 2n. I replaced the head gasket and found a spot where the old gasket failed but the block looks like it might do that again. I don't know why it would do this without coolant in the oil. The tractor does smoke and the compression are mostly even 90psi more or less 3psi difference. Ant ideas?
roger '40 9n
12-03-2007 16:28:53
 Re: Oil in the cooling system in reply to jethro2, 12-03-2007 16:01:27
It is not actually oil. It is combustion by-products getting past the head gasket into the cooling water. There is no oil going through the head so i would not expect water in the oil.
Any water in the oil boils out fairly fast so does not stay there very long.
Roger in Michigan (Brrr)
