Rear axle shims
Phil_in_WA
12-07-2007 22:37:38
Is it possible our fine hosts do not sell rear axle shims? Either metal or paper?
Or am I just blind
Thanks
Phil
OKDAD
12-10-2007 20:09:04
 Re: Rear axle shims in reply to CDEWING, 12-07-2007 22:37:38
Phil,
For 50 cents don't expect a metal shim. This will be a gasket that is used for a shim and stacked to get the desired thickness. I did find the metal shims at the dealer but he wanted around $7 each for them. I'll just use the gaskets!
Sean (TX)
12-08-2007 04:19:31
 Re: Rear axle shims in reply to Sean (TX), 12-07-2007 22:37:38
I dont see them listed under 9N or 8N...I got mine from Helms Farm Machinery He ships same day most of the time..
