Most folks I have to wait till i can git a clean shot,,, knowing you have a bad back you are a EZ kill,,, I take this as a spray wipe and go is not the answer to all ones hydraulic problems that is preached by folks that only know to preach what they have heard as the Gospel. folks seam to for git we are not work'n on a 2000 model that has been used by a little old lady to drive to church on Sunday,,, Not every repair has been done in a sterile environment with a blank singed check in hand. Will admit that I did the best cleaning/rebuild job one could do to a N's belly,,, drove the tractor across town to clean a lot and the bush hog got stuck up would not come down,,, took the inspection cover off pry'ed the control leave back,,, hog hit the ground and its been good to go sense,,, Nature of the beast i figgered. One thang i do know is a N's hydraulics will werk in a rite nasty environment wearers other hydraulic systems will not,,, Demons are unforgiving even with a blank check. Experience and opinions stated here are my own and may not be based on valid memory or sound judgment,,, personal responsibility on your part is required
