Order Ford 9N Parts Online
9N wont start
9n AGAIN
12-17-2007 17:24:04
Howdy, My 9n wont turn over, the ligths all work, battery is fine, it was running great never had a problem starting, went out today and turn he key and push the button and nothing,any ideas?
Thanks
soundguy
12-18-2007 07:44:05
 Re: 9N wont start in reply to 9n AGAIN, 12-17-2007 17:24:04
Do the lamps dime /go out when you try to start it?
Check starter and starter switch connections.
Soundguy
Cody Williamson
12-18-2007 07:08:42
It might help to check your starter brushes.You may also file down on the distributers.
Bruce (VA)
12-17-2007 19:22:02
It doesn't take much in a battery to light up the lights. Jump it (tip # 43 at the link below will tell you how to do it safely) and see if it is the starter. It's probably not; if it turns over w/ a jump, charge the battery & clean all the cables & grounds. Post back if you need more help.
Jerry9n
12-17-2007 18:39:12
You didn"t mention if it"s 6 volt or 12, but you could try taking a jumper cable from the battery side that is not grounded right to the starter lug where the big wire is attached. If the starter spins then the problem is in your starter switch or wiring, if it doesn"t spin you might have a bad starter, or low battery. Since you said the battery is good and the lights work I"d suspect the starter. You could also try pulling the tractor to start it. You could also get a voltmeter and test, you can see all of the wiring exposed from the battery down to the starter switch assembly, and out to the starter.
Good Luck!
Jerry.
9N again
12-17-2007 19:19:22
 Re: 9N wont start in reply to Jerry9n, 12-17-2007 18:39:12
CENTAUR
12-17-2007 17:52:27
I would first start by looseing the battery connections and twistning and retightening them. Hope you have a good battery.Good time to clean them if needed.POST AGAIN IF NEEDED. cENTAUR
