Order Ford 8N Parts Online
Re Replacing 1948 8N Left Axle Shaft
Am-Seb
12-19-2007 09:48:39
I'm going to do some brake work (leaky seal) and also thinking of replacing the left axle shaft, the threads of which were "farmerized" as the locking nut is non-standard (smaller). What steps are involved once the hub and drum are off? Hope it doesn't involve removing the trumpet. If it does I think I'll leave my working tractor as is. Thanks in advance. Angelo
wwildhorse2k1
12-19-2007 18:28:37
 Re: Re Replacing 1948 8N Left Axle Shaft in reply to Am-Seb, 12-19-2007 09:48:39
There is a very good article on rear seals on the Smith site. VERY HANDY!!!
Dan
12-19-2007 11:04:18
If you are replacing the seal, the axle is simply pulled straight out once you get to that point. I suggest investing in an I&T FO-4 manual for this and all other mechanical repairs you may do in the future.
HTH,
Dan
Am-Seb
12-19-2007 16:13:35
 Re: Re Replacing 1948 8N Left Axle Shaft in reply to Dan, 12-19-2007 11:04:18
Dan, thanks for your reply. I do have that manual and a parts book. Now that you pointed it out I don't know how I missed it, but I did. Angelo
Dan
12-19-2007 16:49:48
 Re: Re Replacing 1948 8N Left Axle Shaft in reply to Am-Seb, 12-19-2007 16:13:35
That is good to hear you have the right manuals. Make sure to shim the bearing prelead correct when you put it back together.
Dan
