PTO/ORC Coming Out?
Reid S.
05-28-1999 18:30:13
My overunning coupler seems to be working its way from the main housing. It was up close and snug when I baught my "new" Jubilee. After using the PTO for mostly bush hogging and mowing on weekends for the past two months, the over running coupler I noticed seemed to look different. Some grease has leaked out, as I have greased it only once. There seems to be a gap (about 1/2"-5/8") between the cup of the ORC and pto shaft cover. There seems to be no more play than normal or abnormal operation of the ORC, just a change in the longitudinal position like its wanting to come out. Could it be the ORC or the PTO shaft? Or have I just lost my mind? Looks like it should be an easy check looking at the diagrams...remove four bolts basically, check bearings, snap ring, shaft, etc?? Any thoughts?
Dell (WA)
05-28-1999 18:51:12
 Re: PTO/ORC Coming Out? in reply to Reid S., 05-28-1999 18:30:13
Reid..... ...sounds like you are on the right track. I agree 1/2 spaceing where there was essentually none before definately needs to be looked into. My best guess at this time is your PTO shaft bearing snap-ring has un-snapped. Park your tractor nose down in a ditch so all the fluid runs forward and unbolt your PTO and slide it out.....
Hope this helps..... .Dell
