Order Ford 8N Parts Online
8N Lower Radiator Hose Pressure
1texasjoe
12-22-2007 22:38:05
When engine is running and I squeeze lower hose it feels as if there is no pressure or coolant flowing through hose. Is this normal? Thanks, Joe
Den N Ms
12-24-2007 09:01:54
 Re: 8N Lower Radiator Hose Pressure in reply to 1texasjoe, 12-22-2007 22:38:05
1texasjoe,If you have a thermastat in your N you wont feel any flow till the engine is warmed up and the stat opens up.
Dunk
12-23-2007 18:00:30
Lower radiator hose would be suction wouldn't it?
Yer "N" tractors don't pressure up like yer car does.
4 Lbs, errr less.
Over sized cooling system, on purpose.
You can still stop it up with debris though ifn you don't keep it clean.
dlplost
12-22-2007 22:47:07
Check yer radiator cap, it should be 4 psi
Engine HOT, max water pressure is only 4 psi.
