Order Ford 9N Parts Online
9N Ferguson Rear Blade
petersen
12-23-2007 13:23:15
Recently got this ford 9n and aquired a wagner loader and Ferguson BFO A 21 Rear Blade. The blade had been sitting for a while, found it in a field. The pin to stop the blade from swiveling was rusted in. Spent 2 hours trying to get it out, finally did. Want to know how this pin originally went and worked. If anyone had pictures or manuals it would be a great help. I have included pictures of what I have
Thanks
third party image
third party imagethird party image
Sean (TX)
12-23-2007 17:32:47
 Re: 9N Ferguson Rear Blade in reply to OKDAD, 12-23-2007 13:23:15
Wow...This thread is all
out of wack....No side by
side photos!!!....Tip delete
those photos from photo
bucket....Reset the pic size
in photo bucket to ( 640 x 480 )
Then reload the photos with the
same name. They will show up
smaller.. Looks like a 9n to me.
I beam radius rods..Serial#
indicates 1942 9N..
old
12-23-2007 14:50:04
 Re: 9N Ferguson Rear Blade in reply to petersen, 12-23-2007 13:23:15
Looks like the pin part maybe broken and or missing some parts. By the way the tractor looks more like a 2N then it does a 9N. Almost the same tractors but the 2N is newer by a few years. You need to find your serial number to be sure if it is a 9N or 2N
petersen
12-23-2007 16:42:32
 Re: 9N Ferguson Rear Blade in reply to old, 12-23-2007 14:50:04
Are there anyway to get parts for these? (I'm guessing not) I checked the S/N it's 9N94844 So that would make it a 1942 9n correct? What made it look like a 2N?
Thanks
old
12-23-2007 20:47:56
 Re: 9N Ferguson Rear Blade in reply to petersen, 12-23-2007 16:42:32
Reason I said it might be a 2N was the I-beam arms on it but not sure when they used them. But yes it looks like it might be a 9N. Some times its hard to tell and from what I know the lasat year of the 9N was 1942 but this site says 1943 which should be wrong. So either way you have either a very late 9N or early 2N
Mark Pearce
12-24-2007 03:36:07
 Re: 9N Ferguson Rear Blade in reply to old, 12-23-2007 20:47:56
Old, Me, I'm still tryin to figure out what made you say it was a 2N from the picture. Didn't the 2N use the I beam rods also? And since were talkin bout rods wich ones do you think are stronger? The tube type or I Beam type?
Mark.....
old
12-24-2007 07:39:05
 Re: 9N Ferguson Rear Blade in reply to Mark Pearce, 12-24-2007 03:36:07
I think the I beam type are stronger since I have yet to see any of them bent but I have seen a good number of the tube type bent.
