oil blowing out breather cap
Robert Odegard
12-24-2007 14:45:30
Plowing snow today noticed oil coming out of breather cap. Never done this before does anyone have idea why it would do this? Any help appreciated. Thanks in advance.
Sean (TX)
12-24-2007 15:15:20
 Re: oil blowing out breather cap in reply to Bruce (VA), 12-24-2007 14:45:30
Try cleaning out the breather cap mesh with some spray carb cleaner...Worked for me...
Dunk
12-24-2007 15:00:27
 Re: oil blowing out breather cap in reply to Robert Odegard, 12-24-2007 14:45:30
#1: Are you running a thermostat?
#2: Are you running a thermostat?
#3: How long since the last rebuild?
#4: What are your compression specs?
I am assuming that we are talking about an "N" tractor.
Dunk
12-24-2007 15:01:50
 Re: oil blowing out breather cap in reply to Dunk, 12-24-2007 15:00:27
How long ago was the last oil change?
Dean
12-24-2007 14:58:56
Robert:
You do not say what model tractor you refer to but since this is the N forum and 8Ns are the most common N, I will assume you refer to an 8N.
Flathead Ford tractor engines have no crankcase breather aside from the oil filler tube.
Generally, oil bowing out the filler tube when the engine is working hard is a sign of badly worn rings/sleeves.
It's probably time for a compression test.
How does it start hot/cold?
Dean
Robert Odegard
12-24-2007 19:01:55
 Re: oil blowing out breather cap in reply to Dean, 12-24-2007 14:58:56
Sorry about not giving year or model Iwas a little freaked out about the oil coming out. Its a 48 8n. Yes to thermostat. No to overhaul. When 60 degrees or higher starts fairly good but cold have to pull start it.
