2N radiator filler neck
alanbr
12-24-2007 20:14:16
I have a 2N where the radiator filler neck is bent forward. This makes the back of the winged radiator cap stick up in the air. Is there a good way to straighten up the neck without damaging it?
Thanks.
Bob
12-24-2007 21:36:46
 Re: 2N radiator filler neck in reply to alanbr, 12-24-2007 20:14:16
NOTHING TO IT!
Sick a snug-fitting rod or a dowel into the neck, and tilt it straight.
If the solder cracks loose, slather some "tinning flux" around the neck, then warm up the area around the neck with a propane torch, being careful not to overdo it, so as to loosen the tank from the header, or anything silly like that!
Apply some 50/50 or 60/40 acid-core solder, as needed, and you're done.
Clean up the acid and flux while it's still warm with a brush, and hot soapy water.
Ken Crisman
12-24-2007 20:38:02
Make sure the rad isn't tilted first . If its a problem , remove it & take it to a radiator shop & have it loosened & soldered back in position . HTH ! God bless, Ken
