OT U-Joint plain bearings
Phil_in WA
12-27-2007 14:22:22
Working on an old crawler. Not a Ford but folks here seems to know a lot so I thought I’d ask.
U-Joint between aux transmission and main transmission needs help. No parts available so it’s time to do some machining. The original design was just the universal joint riding in the cast yokes.
My proposal is to:
Turn the universal joint to clean up the 4 shafts (they are in reasonable shape)
Mill out the Yokes to restore a clean circular hole (these are a mess)
Machine a plain bearing with an ID to match shafts and OD to match yoke holes.
Now my question is: Bronze bushings or steel bushings?
Max RPM would be about 1700. Tractor had 23 HP when new 50 yrs ago.
Bob
12-28-2007 05:39:57
 Re: OT U-Joint plain bearings in reply to Phil_in WA, 12-27-2007 14:22:22
Special tough U joints for extreme 'wheeling use bronze bushings, so I think that may be the way to go.
See link.
Den N Ms
12-27-2007 17:59:38
Bronze bushings will last along time if you machine the OD press fitted in the yokes after milling the yokes out.ID .002-.004 on your joints and you keep them greased.
old
12-27-2007 15:21:57
What brand of crawler is it???? If its what I am guessing it is the u-joints can be found for it. So tell us/me what it is and I may know where you can buy them.
Phil_in_WA
12-27-2007 17:10:12
 Re: OT U-Joint plain bearings in reply to old, 12-27-2007 15:21:57
OC-46.
I did find some but a price that knocked me flat.
I have a large lathe and mill at work so this seemed far more attractive (and fun?)
Thanks
Phil
old
12-27-2007 17:59:43
 Re: OT U-Joint plain bearings in reply to Phil_in_WA, 12-27-2007 17:10:12
Ok so I'm guessing you know about Zimmermans then and thats probably where you found them, Right??
Phil_in_WA
12-28-2007 09:03:07
 Re: OT U-Joint plain bearings in reply to old, 12-27-2007 17:59:43
Yep
I've bought stuff from them before and they were great. The U joint was probably a fair price but way more than I wanted to spend :-)
Mark Pearce
12-28-2007 06:00:10
Old, This info is TOP SECRET! We have a don't ask don't tell policy in place.
Mark...
Dean
12-27-2007 14:34:11
I'd recommend bronze.
Bronze bushings should outlast you in this application.
Dean
