clutch input shaft seal
Robert Underwoo
12-28-2007 12:13:10
Hi Everyone, I,m replacing the clutch on my 1950 ford 8n w/dist. on the side. This tractor has the Sherman transmission for four hi; and four low. Is that front input shaft seal avalible,or is there a p/n. The seal is in my I&T shop service manual fig. fo98 item 26 oil seal. THE clutch disc was oil soaked.. Thanks
Robert Underwood
12-29-2007 04:20:22
 Re: clutch input shaft seal in reply to Robert Underwood, 12-28-2007 12:13:10
Thank you for the info. My local tractor shop did not know that input seal are the same. As of now, I'm $280 in parts ; clutch kit, clutch pedal arm bushing & shaft bushing, clutch releae arm kit, release bearing hub, and starter flywheel ring gear which need changed a few years back..SO MUCH FOR THAT CAN OF WORMS. thanks angin..
jimNCal
12-28-2007 13:48:12
Aside from this site, I sent you an e-mail with a couple of sources for parts.
jim
soundguy
12-28-2007 12:15:02
The sherman takes the standard N tranny input shaft seal.. a very low$ ticket item.
Soundguy
