Hub rubs on brake spring
awful noise like scratching fingernails on a black board, Arghhhh!!!
Phil R (IL)
05-29-1999 18:58:27
When I tore my 8N down to replace seals, I noticed the left brake spring was badly worn. I replaced it and the hub really rubs on it. I presume it is a bad hub, axle or both. Is there any way to determine which of those might be the culprit or am I destined to replace both to rid myself of that aggravation.. Thanks in advance for your help, this is a great BBoard.. p
Jim
05-30-1999 06:38:33
 Re: Hub rubs on brake spring - awful noise like scratching fingernails on a black board, Arghhhh!!! in reply to Phil R (IL), 05-29-1999 18:58:27
I had the same problem on my NAA when I put new shoes in. I must have taken it down three times and never could find anything rubbing. Then I went into the right hand side again and put an extra spring in. That helped a lot. Much later, I read the book, a little late and learned that there is a different combination of springs on the left and right hand side. Check your Ford operators manual for 8N.
bg
05-29-1999 19:59:19
Which spring? 2299? 2297? or the adjuster spring?
jim
06-01-1999 03:18:46
 Re: Re: Hub rubs on brake spring - awful noise like scratching fingernails on a black board, Arghhhh!!! in reply to bg, 05-29-1999 19:59:19
2297 is used on the left hand side of tractor only, according to the book. The 2299 would then be used on both sides.
ya never know...bg
06-01-1999 06:08:27
 Re: Re: Re: Hub rubs on brake spring - awful noise like scratching fingernails on a black board, Arghhhh!!! in reply to jim, 06-01-1999 03:18:46
When I got my 8N the brakes were installed upside down and backwards with springs and coathanger wire holding things together. You never know what to expect when you open a can of worms.
