New battery cables
rd99
12-31-2007 06:50:38
My starter motor quit turning the engine over. There was no click or anything on my 1947 2N.
I could hand crank the engine fine.
I got some new battery cables and cable to the starter which fixed it.
It really cranks up well now. I've got the original 6v system, and with the new cables it cranks up like it did when I had to jump it from a 12v back when I picked up the tractor from my grandfather earlier this summer.
It starts up immediately. Previously it had the original 1947 cables, which upon inspection had the inner strand wires corroded/severed.
Some of you guys thinking of doing a 12V conversion, if you don't need the 12V for some other electronics, might just need replacement battery cables.
Ltljon
12-31-2007 20:28:20
 Re: New battery cables in reply to Colin King, 12-31-2007 06:50:38
Dell (WA) said: (quoted from post at 21:21:05 12/31/07)
Seriously, consider yer 2-gauge an EMERGENCY cable and gitt a real HEAVYDUTY 1/0 gauge (thick as yer thumb) battery cable of appropriate length. $10 (cheap leason)..... ..Dell
Mucho thanks, advice taken.
Dunk
12-31-2007 15:41:05
 Re: New battery cables in reply to rd99, 12-31-2007 06:50:38
Amen!!
Ltljon
12-31-2007 15:12:45
 Re: New battery cables in reply to Mark Pearce, 12-31-2007 06:50:38
I remember reading sometime back how important good cables are on a 6 volt but what guage cables are recommended? I had to replace one this week & bought a 2 guage. They had a 1 guage but it was too long so hopefully the 2 is sufficient?
Dell (WA)
12-31-2007 20:21:05
 Re: New battery cables in reply to Ltljon, 12-31-2007 15:12:45
Ltljon..... ...you ask what "gauge" for yer 6-volt battery cable. p/n 14300 cable, battery, 1/0 gauge (one-ought) is what is recommended for 6-volts. 2-gauge is too skinny and is fer belchfire-V8 12-volt heavy duty applications. Most wimpy rice-rockets use 4-gauge.
Of course Ford spec's for the 2N-10655C battery is "13-plate" domestic. Don't say 'nuttin' about being 6-volts.
Bruce (VA)
12-31-2007 14:29:17
Thanks for the post; it should be archived under "Common sense & good judgment"!
A 12v conversion is money well spent if you need bright lights or need to operate 12v auxiliary equipment.....or, you have low compression & do not have the time/money for a rebuild. But, IMHO, spending as much as $200 for a 12v conversion because the tractor is hard to start doesn't make a lot of economic sense to me. I can spend $200 on stuff other than tractor parts I don't need and get the tractor to start on 6v for a lot less $$$. I'm surprised that more folks don't advocate converting the N to fuel injection.....makes as much sense in many cases as a 12v conversion.
GB in MT.
12-31-2007 07:02:41
Good thinking RD!!!third party image I don't know how many times, I've seen DELL, and some of the other guys on here, that know, Post to do this very thing.
Corrosion on elec. is a power killer!!!!!
Bright and tight!!!! That is the ticket.
Garythird party imagethird party image
justin14054
12-31-2007 07:00:27
Yup,Yup,Yup
Just my $.02 worth.Nothing wrong at all with 6volt system.It is all in thick cables
Justin
