Replace Brake Shoes and an Axle Shaft
Am-Seb
12-31-2007 09:26:01
Leaky left wheel. Now know from this Board to keep gear oil at bottom hole of inspection plate. I'm (hopefully) getting an experienced N'er to do the above--both wheels and left axleshaft (farmerized threads and nut) on my '48 8N. All appropriate literature; new parts and tools on hand; working indoors; helper for moving wheels and cleaning parts--me!; and presume no set-backs About how long should I figure time-wise? Thanks in advance and Happy New Year to all. Angelo
Dunk
12-31-2007 15:34:10
 Re: Replace Brake Shoes and an Axle Shaft in reply to Am-Seb, 12-31-2007 09:26:01
Just one note here.
You are talking about brake shoes, and axel shaft.
You have one more variable on the 48 8N, and that would be worn hubs.
If your hub(s) are worn out, you won't ever get it to stop leaking, unless you replace it/them.
Am-Seb
12-31-2007 16:01:14
 Re: Replace Brake Shoes and an Axle Shaft in reply to Dunk, 12-31-2007 15:34:10
Thanks, Dunk. Both wheels are very solid; don't get any movement at all rocking them. The leak appeared not too long after a local Ford dealership supposedly fixed the brakes. I first noticed leakage at the left axle nut and after a while that brake wasn't working. Will know more when hubs are off. Angelo
Phil_in_WA
12-31-2007 13:17:32
Let me know how it goes. I have a '48 with leaks and all the parts waiting for me the next time I visit the tractor.
Happy New Year
Am-Seb
12-31-2007 14:46:12
 Re: Replace Brake Shoes and an Axle Shaft in reply to Phil_in_WA, 12-31-2007 13:17:32
Phil in WA. Will do. Angelo
Dan
12-31-2007 10:00:20
If this is your first time - probably about 2-3 hours. I can now do it in about an hour, but that is because I take my time and get the bearing preload perfect.
Dan
Am-Seb
12-31-2007 11:13:54
 Re: Replace Brake Shoes and an Axle Shaft in reply to Dan, 12-31-2007 10:00:20
Dan, thanks a lot for the prompt reply--I'll enjoy New Year's Eve even better now. Hope you have a good one. Angelo
