Order Ford 8N Parts Online
9N oil pan same as 8N?
GunPilot
12-31-2007 09:37:36
I have an 8N block with no oil pan, and there's a "9N" pan on Ebay. Is the 9N pan interchangeable with the 8N, (front dist) considering it will be mounted back up to the 8N tranny? Thanks O wise gurus of the N.
-George
GunPilot
12-31-2007 18:10:19
 Re: 9N oil pan same as 8N? in reply to Gaspump, 12-31-2007 09:37:36
The reason I ask is I have a wild hair to build a "Raggedy Ann" tractor... see I have all these leftover parts that aren't good enough to put on the resto but are really quite serviceable once you get past the warts. I have basically the entire drivetrain of an 8N - block, trans, rear end, axle trumpets, etc. I figure I'll keep collecting parts as I go and sooner or later have another complete tractor. She won't be pretty but I bet she runs all right.
GunPilot
12-31-2007 10:03:13
 Re: 9N oil pan same as 8N? in reply to Dell (WA), 12-31-2007 09:37:36
Very good - thanks. I am geographically separated from my manuals so I'm deaf dumb and blind. Thank goodness for the internet.
-G
dlplost
12-31-2007 09:54:24
 Re: 9N oil pan same as 8N? in reply to GunPilot, 12-31-2007 09:37:36
YES, My parts book says only one oil pan from 1939 to 1952, there all the same.
Dan
12-31-2007 10:05:29
 Re: 9N oil pan same as 8N? in reply to dlplost, 12-31-2007 09:54:24
Well - yes and no. Yes, they will all bolt up to any engine from 1939 to 1952 so your answer was acurate, but the early 1939 9N oil pans were designed a tad differently as far as the lines and angles in the sides of the pan. True, that does not stop you from using a early 1939 9N oil pan on a 1952 8N engine, but it was a cool discovery I made when I had to replace my 1939 9N oil pan due to cracks the previous owner made overtorquing the bolts.
Dan
Dunk
12-31-2007 18:12:49
 Re: 9N oil pan same as 8N? in reply to Dan, 12-31-2007 10:05:29
A werkin tractor, is a werkin tractor, I don;t care how you spell it.
