Order Ford 8N Parts Online
8n 12 volt battery
Phil Marion
12-31-2007 21:39:42
Is a 12 volt battery available with the terminals located diagonally (same config. as original 6 volt)?
Dunk
01-06-2008 16:05:38
 Re: 8n 12 volt battery in reply to hiramelu, 12-31-2007 21:39:42
Phil Marion said: (quoted from post at 20:55:21 01/06/08) Both...It looks as though the original cables that I purchased will only fit if the terminals are diagonally located on the battery.
Which one is too short?
The Ground?
The cables come in different lengths.
John, Ind.
01-02-2008 07:31:18
 Re: 8n 12 volt battery in reply to Phil Marion, 12-31-2007 21:39:42
You can buy a 12 volt batt. with the positive on the right or left side of the battery. 12 volt conections are normally in the corners as opposed to 6 volts in the center of the narrow end.
Bob
12-31-2007 21:56:39
NOT as far as I know, unless from a specialty outfit making original-looking 12-Volt batteries for vehicle restorations.
WHY is this important to you... for APPEARANCE,or FUNCTION?
Phil Marion
01-06-2008 15:55:21
 Re: 8n 12 volt battery in reply to Bob, 12-31-2007 21:56:39
