Order Ford 8N Parts Online
8n rings
Eriklane
01-02-2008 06:29:34
1948 8N has 1 cyl with low pressure(65). I want to replace the sleeves/rings this spring. Have read the lit. online here and really feel inadequate to do the job, but know in my mind, basically what to do. Can someone give me their phone # so I can talk through the process? I'll pay the phone bill(unlimited) so its no problem. What I'm trying to do is come up with a bullet point document outlining everything to do.
Also, how do you determine what rebuild kit to buy? How many hours does it take to redo sleeves/rings (not taking motor out).
Thanks
Eriklane
01-02-2008 10:11:54
 Re: 8n rings in reply to Eriklane, 01-02-2008 06:29:34
my email is erik.lane.broekhuizen@gmail.com
old
01-02-2008 09:28:25
Send me an e-mail and I'll give you my phone number. Or you can look in my web site for it. Do the wet test and it can/will tell you a lot more as to whats up with your engine. Also running it with say 1 QT. of tranny fluid with 5 gal. of gas can help if you have sticking rings or sticking valves. MMO works also but tranny fluid will cost you about half of what MMO costs
Eriklane
01-02-2008 06:56:41
No. I need to do a wet test. If the wet test shows a good comp. #, what then do I do for a valve check/fix?
souNdguy
01-02-2008 11:51:53
 Re: 8n rings in reply to Eriklane, 01-02-2008 06:56:41
I agree with the others.. do a wet/dry test.. then go from there.. if the valves are bad.. the ring job gets you nowhere..
Soundguy
BillM (OH)
01-02-2008 08:28:30
If a wet test brings it up significantly, it's rings, if no improvement, it's valves & go from there.
TheOldHokie
01-02-2008 06:49:27
 Re: 8n rings in reply to GunPilot, 01-02-2008 06:29:34
Are you sure it's rings and not vlaves?
TOH
HCooke
01-02-2008 07:23:44
 Re: 8n rings in reply to TheOldHokie, 01-02-2008 06:49:27
TOH, Happy New Year. I've been lloking for you to post. I would like to order a early 9N pin and your cylinder liner remover tool.
TheOldHokie
01-02-2008 10:47:39
 Re: 8n rings in reply to HCooke, 01-02-2008 07:23:44
Sure thing - drop me an email:
TOH's eMail
TOH
