Need a Junk Front Mount Coil
Kevin in MN
01-04-2008 19:03:49
Anybody have a Junk front mount coil laying around?
I want to use it to make a remote mount coil adapter
Shoot me and e-mail and we'll work something out
Thanks
Kevin
kevins@generalparts.com
jon
01-06-2008 11:28:43
 Re: Need a Junk Front Mount Coil in reply to Dunk, 01-04-2008 19:03:49
Joe)NYC) said: (quoted from post at 20:14:29 01/05/08) $35 for a new 6 Volt battery? You stole it. I just bought a 6 volt bat at Advance Auto and it was $59. The previous one I bought there was $35. about 4 years ago. Good for you. But where did you buy it anyway. I could use to save some money next time.
I almost did the same thing. Advance & Auto Zone were both $59 but remembered Tractor Supply was $39. Had to drive a little further but picked up some other stuff there too.
Hobo,NC
01-05-2008 08:53:58
 Re: Need a Junk Front Mount Coil in reply to Kevin in MN, 01-04-2008 19:03:49
You could add a 12 to 6V drop'n resistor on it,,, and a 12V battery,,, long as you did not run headlights you could run it for weeks on a charge. Guy i know does just that,,, has run it like that for years,,, he mite use a 12V front mount coil tho,,, it would B safe using just the OEM resistor.
Tom N MS
01-05-2008 09:09:31
 Re: Need a Junk Front Mount Coil in reply to Hobo,NC, 01-05-2008 08:53:58
That's how mine was when I got it..no generator, no OEM resistor, just the 12 to 6V dropping resistor..Had been that way for years, and of course had the orig. style 6V square coil... Shoulda just left it that way.
Kevin in MN
01-05-2008 07:36:13
Looks Like I've got one comming. Thanks for everybody's input!
Kevin
Colin King
01-05-2008 07:27:05
Kevin,
I have one I can give you that still has some life in it. I'll be going up to the farm next weekend, and I can bring it back with me then. I'm in Minneapolis.
My email is open - or vashtarbin at hotmail dot com
But I gotta question your rationale for your needed conversion. A replacement 6volt VR is $26 bucks, a genny brush set is $3.5, and a new 6volt bat is $35. Total is less than half what it'll cost you to buy the 12 volt conversion kit - and you still need a battery after you buy the kit.
Colin
Joe)NYC)
01-05-2008 19:14:29
 Re: Need a Junk Front Mount Coil in reply to Colin King, 01-05-2008 07:27:05
Colin King
01-06-2008 07:56:01
 Re: Need a Junk Front Mount Coil in reply to Joe)NYC), 01-05-2008 19:14:29
Joe, You prompted me to double check my receipt. Yes, I paid $35 + tax at a local shop. It's a battery labeled by a local company out of St. Cloud, MN - I can't recall their name right now. I've now had it 2 years. It cranks fine at well below zero, and has survived overcharging due to a faulty VR when first installed.
Colin
Kevin in MN
01-05-2008 06:20:52
Well... at the moment I have a bad regulator, a week generator and an old battery. So 12v now looks to be the way to go for continued reliability.
That path means I need to do something with the 6v coil set up. I large resistor on the aftermarket 6v coil I have just doesn't sound like a good idea, and from what I read about the reliability of the current oem style 12v coils that isn't much better. So gutting a coil to make an adapter to a "modern" coil is the next plan. And of course I'd prefer to do this with a junk coil while mine is still running.
Oh ya, then at last I can install the cool vintage 12v fender radio I picked up on eBay.
Kevin in MN
01-05-2008 06:06:57
Cottage Grove, Just North of Hastings.
stumped,decorah,Ia
01-04-2008 21:12:16
Where in Mn. are you located I may have one. Im located just across the Ia, Mn. stateline.
old smokie
01-04-2008 20:29:53
i have one getin it from florida may cost more than a new on.
35A
01-04-2008 19:58:15
I've got an old one I took off years ago. Both of my tractors are 6 volt and never saw a need to go to 12 volt. Now, the Farmall M was another story. I can't understand why folks want to go 12 volt on so many old tractors like the Fords.
Kevin in MN
01-04-2008 19:27:41
yep, you figured it out!
Hobo,NC
01-04-2008 19:57:55
 Re: Need a Junk Front Mount Coil in reply to Kevin in MN, 01-04-2008 19:27:41
I'm not gonna spank ya,,,, keep a eye out tho,,, sum git off wif the whip,,, I plan to spend all my money,,,, were I am headed I here it will burn,,, no need to take it wif me.
Hobo,NC
01-04-2008 19:23:44
Alrite Kevin confess what ya hide'n,,, izz yer tractor worn out and you need a 12V band-aide. Iffin I had one 2 spare I would send it to ya,,, I sell'em as fast as I can git ahold of'em,,, makes folks rite happy to see their tractor run better than new and B dependable
