Compression Testing Results
Anvilheadtexas
01-07-2008 13:28:02
I have posted about my project 8N before. I have the tractor stripped down fairly well. I am taking it down because of a bad blow by and low compression problem on cylinder #1. I have monitored a lot of posts on this site regarding poor compression and I got to thinking that maybe I had a stuck valve. So I did another compression test yesterday. This time I had the valve covers off and I was able to watch the valves. I assume if the valves are "stuck" they would not move? Anyway, the valves looked like they moved up and down. The compression came back 95 plus on 2,3 and 4. Number 1 is still 60 psi? I am still a new comer - go easy....seeing that the valves went up and down can I conclude the compression problem is not a valve problem. Also, there is NO odd sounds (like rings scraping up against the cylinder wall). I ran out of time to do a wet compression test. Also, the manifold is off - does that affect the compression test?
teddy52food
01-07-2008 14:30:47
 Re: Compression Testing Results in reply to Anvilheadtexas, 01-07-2008 13:28:02
Male an adapter so you can put air pressure in the spark plug hole. Listen and find out where it is leaking. If it goes to the crankcase it is the rings . If it is in the exaust or intake port it would be a valve. (Most likely) You may have to turn that piston to TDC put the tractor in high gear and lock the brakes.
Dell (WA)
01-07-2008 14:11:59
Tex..... ..would it surprize you to learn that a BURNED EXHAUST valve will also cause LOW compression??? besides stuck valves. Burned valves are more common than stuck valves. Do a "wet" test on ALL cylinders so you have a valid comparison. Besides having stuck rings, you could also have a burned piston or broken rings. Manifold off'n or on should have NO effect on compression readings. Ford SPECS: 90psi min (dry)..... ....Dell
russbWA
01-07-2008 13:40:52
I would give #1 cyl a soak in Marvel Mystery Oil, 3-6 ounces, through the plug hole for a few days, hoping the problem is just a stuck ring. Depending on your values (do unto all cylinders as one). But, I would just do the one.
Doing a compression test with out the manifold is fine. HTH
BillM (OH)
01-07-2008 14:01:37
 Re: Compression Testing Results in reply to russbWA, 01-07-2008 13:40:52
Wet test on #1 should tell you whether it's valves or rings.
