KKK..... ...believe it or not, them resistors are supposted to gitt HOT!!! (burnie-burnie) Enny short in yer wiring would also MELT the plastic wiring insulation. Since you neglect to tell us whether yer ignition system is a squarecan coil frontmount or the 5-nippple sidemount with roundcan ignition coil, I'm gonna display my amazing mindreading ability and guess because you mention 2-resistors in a 12-volt conversion, you must have the weird 4-nipple frontmount. The voltage at the top of the 1-terminal 6-volt squarecan ignition coil should read about 3-volts at cold start-up and when warmed up will drop down to about 2-1/2 volts. Ennythang less than 2-1/2 volts, yer gonnna be haffin' sparkie problems. You do realize that depending upon the individual resistance values, the voltages across each resistor could be quite different. Its the LAW!!! Kirchhoff's Law. Its the volts at the TOP of the ignition coil that really matters..... ..Dell, yer self-appointed sparkie-meister
