Order Ford 8N Parts Online
1948 Ford 8N
Roo
01-07-2008 15:03:18
Hello, I need some experienced advice. I had recently purchased a 1948 Ford 8N. The engine was overhauled about six years ago and runs great, but I noticed that with the tractor running and not in gear AND clutch out, the is a "whirring" sound coming from somewhere. When I push in the clutch, the sound stops. When I let out the clutch (tractor running & not in gear), the "whirring" starts up again. Does anybody have any ideas what this could be? Is this fairly common in Ford 8N"s?
Any input is greatly appreciated!
Thank-you,
Bart
LeeMo
01-08-2008 10:49:55
 Re: 1948 Ford 8N in reply to Roo, 01-07-2008 15:03:18
Not real unusual and unless it gets to be a growl it's probably no big deal. I'll guess it's the tranny input shaft bearing like others mentioned. I've heard a few that do that with no problems.
Britcheflee
01-07-2008 22:05:10
 Re: 1948 Ford 8N in reply to Ed S. (IL), 01-07-2008 15:03:18
H Kutzler said: (quoted from post at 22:34:33 01/07/08) I think it could be your pilot bushing located in your flywheel. If yoy split your tractor replace it with an altinator bearing as they fit just right.
Before you go and rip the tractor apart please check the pto bearing - I had a very worrying noise coming from some undefined area - turned out to be the pto bearing which was totally shot.
To me a whining noise is not as scary as a grinding or rumbling noise which implies something more drastic.....my kids whine all day but they still are fine@!
Lee
H Kutzler
01-07-2008 21:34:33
Sheltie007
01-07-2008 19:07:00
I recently looked at a 1950 8N to purchase and it had that same sound you heard, and decided not to buy it. I now own a 1951 8N and it has the same "whirring" noise with it not in gear and the clutch out. My 8N has always been maintained by the previous owner and kept in a shed after farming chores. It runs great without any problems and looks good too. Just thought you would like to hear from someone with the same noise.
ZANE
01-07-2008 17:17:43
Sounds like it is the input shaft bearing and maybe the input shaft gear.
Zane
Roger in Iowa
01-07-2008 15:28:24
Dis-engage the pto and hydraulic pump. Lever is by your left heal when seated on the tractor. Move the lever forward to dis-engage. Does the whirring stop?
Roger in Iowa
Roo
01-07-2008 16:09:13
 Re: 1948 Ford 8N in reply to Roger in Iowa, 01-07-2008 15:28:24
Thank-you Roger,
I will try this and let you know.
Thank-you,
Roo
Ken Crisman
01-07-2008 15:18:51
Sounds like throw out bearing to me . May mean a split in the future for you . God bless, Ken
Dell (WA)
01-07-2008 15:30:03
 Re: 1948 Ford 8N in reply to Ken Crisman, 01-07-2008 15:18:51
Ken..... .throw-out bearing only works when yer steppin' on the clutch pedal. His noise goes away when he steps on the clutch pedal.
Roo..... .yer tranny noise is probably yer tranny input bearing. Very common and NOT a problem. Yer tranny input bearing is splash lubed by an oil-slinger. Don't OVERFILL yer hydro-tranny 'cuz that'll kill yer clutch disc and yer rearaxle brakes. I wouldn't worry about it..... .Dell
Ultradog MN
01-07-2008 17:22:14
 Re: 1948 Ford 8N in reply to Dell (WA), 01-07-2008 15:30:03
Good advice.
