Order Ford 8N Parts Online
8n tractor with truck coil
rc werden
01-09-2008 14:06:27
During a recent farm tractor show a guy with a 8n had a truck coil hooked up to the 8ns ford front mounted coil. He had drilled a hole in the 8n coil soldered a wire to the rotor contact then ran the wire to the truck coil. Has anyone ever heard of this and does anyone know what kind of truck coil to use and how to do it?
JMOR
01-10-2008 18:48:00
 Re: 8n tractor with truck coil in reply to Wayne1, 01-09-2008 14:06:27
Hobo,NC said: (quoted from post at 22:37:28 01/10/08) Damm you are good,,, I never caught that,,, in a rush converted that one and it got trowed on top of the tool box,,, made the change,,, did steel the pix tho,,, Thanks
Unpdated link
You are more than welcome! I've learned more from you than the other way 'round.
JMOR
JMOR
01-09-2008 19:56:18
 Re: 8n tractor with truck coil in reply to diverjeff, 01-09-2008 14:06:27
Hobo,NC said: (quoted from post at 23:50:58 01/09/08) Just happen to know,,, For the most part if a customer has enuff money i can make it trouble free,,, theirs a post down b-low with a point problem,,, I would bet the farm the distributor izz worn slap ares out. A external coil is by all means a UPGRADE frome the piece of sheet ford put on it,,, well 60 years ago,,, times have changed.
coil conversion
Pickin nits.....I know!
Bale flips off easier if wire is on other side.
third party image
Hobo,NC
01-10-2008 18:37:28
 Re: 8n tractor with truck coil in reply to JMOR, 01-09-2008 19:56:18
Hobo,NC
01-09-2008 19:50:58
 Re: 8n tractor with truck coil in reply to rc werden, 01-09-2008 14:06:27
rc werden
01-09-2008 15:50:13
sorry guys to expand the reason was he had no luck with the tractor coils it seems they didnt last. The guy was retired and owned a large tractor dealership he loved old tractors but got tired of changing the off shore coils.
soundguy
01-09-2008 17:59:15
 Re: 8n tractor with truck coil in reply to rc werden, 01-09-2008 15:50:13
He probably changed coils alot because he did not run the correct resistance in series with them.
I find it strange why people will be willing to change a 26-50$ coil every few months.. but won't add a 50 cent to 12$ resistor 1 single time... go figure!
soundguy
soundguy
01-09-2008 14:17:11
I'ts quite common to farmerize in a round can coil in place of the square coils. some people gut and old square coil for this.. others make blank plate.
there is a kit available to do this.
if the machine is still 6v.. use an 8n 6v round coil and no ballast resistor. if the machine is 12v, use a NAPA IC14SB 16$ coil.. and no ballast resistors.
soundguy
LenND
01-09-2008 14:10:58
I wonder why he would go to all that trouble. Why not just put in a new coil. Looks like he hasn't tried to find the original problem.
JMOR
01-09-2008 14:28:04
 Re: 8n tractor with truck coil in reply to LenND, 01-09-2008 14:10:58
Or maybe just got tired messin' with NWAS square can coils.
LeeMo
01-09-2008 14:25:12
Probably had a truck coil in hand and no money for a new coil.
Bob
01-09-2008 19:31:52
 Re: 8n tractor with truck coil in reply to LeeMo, 01-09-2008 14:25:12
How do we KNOW it's a "truck" coil and not a "car" coil????
LeeMo
01-10-2008 09:04:58
 Re: 8n tractor with truck coil in reply to Bob, 01-09-2008 19:31:52
"we" don't. It's what we were told. Please read above postings.
