Ignition switch
rd99
01-10-2008 15:40:53
Why is it referred to as a weaksister?
roger '40 9n
01-10-2008 15:56:54
 Re: Ignition switch in reply to rd99, 01-10-2008 15:40:53
Here is the Dictionary.com definition:
Main Entry: weak sister Function: noun Date: 1857 : a member of a group who needs aid; also : something weak and ineffective as compared with others in a group
In reference to Ford "N" tractors it means that it is a weak component in the ignition chain. And likely to fail before other parts do. The current for the ignition has to go through the ignition switch, through the ballast resistor, through the coil, through the points, through the distributor, to ground.
Also means that it is undersized for the job. And if the current for the lights is also run through it it will fail sooner.
Roger
Peter, Covington, LA
01-10-2008 15:49:42
Because of the regularity with which they fail.
R.G.M.
01-10-2008 16:01:33
 Re: Ignition switch in reply to Peter, Covington, LA, 01-10-2008 15:49:42
Peter I live just south of you in Slidell Ive got two Ns a 8 and a 9 whatch ya got Rick?
R.G.M.
01-10-2008 16:01:26
01-10-2008 18:23:59
 Re: Ignition switch in reply to R.G.M., 01-10-2008 16:01:26
One 9N. How did you fare in "the recent unpleasantness?"
