Order Ford 8N Parts Online
8N Starter Drive
Al
05-31-1999 13:21:08
The starter drive (ratchet type) on my 8N keeps sticking (rusting) stuck. I have hole sawed an opening in the flywheel housing so I can reach in and pry it loose with a screwdriver. There must be a better way. Should I use a particular kind of grease or leave it dry?
bg
05-31-1999 17:39:09
 Re: 8N Starter Drive in reply to Al, 05-31-1999 13:21:08
Why is it rusting? Maybe because you have a hole drilled in the flywheel housing? ;^) I'd replace the bendix with a new one. Lubrication will exacerbate the problem.
