Order Ford 8N Parts Online
8n ignition
ron werden
01-13-2008 13:21:06
with 12 v system on 8n can you use a voltage regulator between the ignition switch and coil instead of resistors?
soundguy
01-13-2008 16:12:04
 Re: 8n ignition in reply to ron werden, 01-13-2008 13:21:06
My guess is a solid state vr would soon croak in an ignition circuit. If it is a frontmount get a 12v coil and a resistor combo to get you between 3a and 4a.
if it is a side mount. get a REAL 12v coil like a napa ic14sb and forget about the resistors.
soundguy
old
01-13-2008 14:59:28
Well yes maybe if its a solid state type VR. But if its the old relay type no because the way they regulate is by opening and closeing the relays and when the relay opened you would loose your voltage to the coil
Ken Crisman
01-13-2008 13:50:18
Why switch to 12 v & have these concerns ? If you keep all connections clean & brite with a good 6v battery , it should start ok . I did switch my 2 old Fords to 8v years ago . The only change I had to make was the VR had to be tweaked to assure around 9.6v was being put back into the battery . In the 7 or 8 years I've only had 1 headlite burn out & replaced 1 battery after 5 yrs of use . Everything stays as 6v . Good luck & God bless, Ken
JMOR
01-13-2008 13:48:55
 Re: 8n ignition in reply to Hobo,NC, 01-13-2008 13:21:06
ron werden said: (quoted from post at 17:21:06 01/13/08) with 12 v system on 8n can you use a voltage regulator between the ignition switch and coil instead of resistors?
Well,..... ....I suppose, but since a 12v system typically runs at about 14.8 volts and a 6v coil at 2.45volts according to Ford spec sheet, that is a 12.35 volt drop across your regulator at about 3 to 4 amps or about 36 to 49 watts of heat for it to dissipate.
That will take a pretty hefty regulator. But possible.
