Order Ford 8N Parts Online
LOHI RANGE IN 8N FORD,RIGHT SIDE LEVER
STEVE ONEAL
01-13-2008 16:51:25
MY BROTHER OWNS A 1949 8N FORD WITH A LOW AND HIGH RANGE LEVER IN THE RIGHT HAND COVER BESIDE THE TRANSMISSION DIPSTICK. I DROVE THE TRACTOR TODAY AND IT HAS 8 FORWARD GEARS AND TWO REVERSES.DOES ANYONE KNOW ANYTHING ABOUT THIS PARTICULAR TRACTOR.PLEASE RESPOND WITH ANY INFO.
STEVE ONEAL
01-13-2008 20:06:02
 Re: LOHI RANGE IN 8N FORD,RIGHT SIDE LEVER in reply to STEVE ONEAL, 01-13-2008 16:51:25
THANKS A LOT GUYS,THE PICTURE OF THE HOWARD ON MARVINS TRACTOR LOOKS EXACTLY LIKE MY BROTHERS TRACTOR.I REALLY APPRECIATE THE INFORMATION.I KNOW HE WILL BE EXCITED ABOUT THE NEWS.
Cutter
01-13-2008 20:05:13
First...you do not have 'HI/LO'. You have 'REGULAR(standard)/LO'. That IS the shifter handle for the 'Howard' gear reduction made by Rotary Hoes of Essex, England in the right inspection cover.
As Dell said, it is NOT a pulling gear! It is a groundspeed reducer of 3.5 to 1 to enable the use of a 'roto-tiller'. Abuse it at your peril.
Dell (WA)
01-13-2008 18:53:27
Steve..... ..you've described the shifter location in the 6"-round dipstick plate behind yer right heel for the rare and fragile "Howard" aux tranny. (its real name is NOT Howard, but everybody calls it that) Valuable low speed for rototilling operation. IT IS NOT A GRUNT GRANNY GEAR. It is about 2.75 times reduction for PTO operation of rototillers. Most N-Tractors are too HI-SPEED for rototilling operation, hence the need for slow-down tranny..... .....Dell
GunPilot
01-13-2008 18:03:04
That sounds like the rare Howard transmission. Check this page:>Link
third party image
Ken Crisman
01-13-2008 17:02:02
Go to John Smiths website . He has all the auxillary trans listed & described . The hi range you think you have could be one of two ways . Either its in the regular gear ratio which you think is low & then when you shift the lever it goes to high range . Or it could be that the high range is the standard gear ratio & when you shift to low range you do have the low range . Hupp made it both ways . Hupp has the handle on the right side when you sit on the seat . Sherman is on the left side & is a much better auxillary trans of the two mentioned . The low range Hupp is the besty of the two made by Hupp . With these little Fords you need power not speed ; unless for road traveling . HTH ! God bless, Ken
Dunk
01-13-2008 16:59:46
I know that me, and my 49 8N *236763*, are jealous, of the low range!!
