Order Ford 9N Parts Online
9N RPM
RonS
01-14-2008 15:38:32
I"m new to the 9N. Does it have an RPM governor? Mine doesn"t seem to want to rev up very high.
soundguy
01-14-2008 17:07:08
 Re: 9N RPM in reply to RonS, 01-14-2008 15:38:32
Gov is on right font side of engine.
check your linkage to your carb.. it runs from the governor.. and your throttle linkage runs tot he governor from the dash.
springs should have no preload and no tension
soundguy
Yes..John,PA
01-14-2008 15:44:52
Most 9N's have a governor. Idle speed should be 'bout 400 rpms. Somewhere's around 1800 to 2200 rpm would be good for high engine rpm, I think. HTH
