Trickle charger for 6 volt batteries
Britcheflee
01-16-2008 15:36:47
Would this work on the 6 volt battery in my 8N?
Link
If not, any suggestions as to suitable trickle charger?
Thanks,
Lee
JMOR
01-21-2008 08:15:39
 Re: Trickle charger for 6 volt batteries in reply to CENTAUR, 01-16-2008 15:36:47
soundguy said: (quoted from post at 09:02:31 01/21/08) Take a re-read of what you just posted. The circuit breaker that is in the dc output line is in series with the secondary of the xformer... if a diode shorts in a half wave config, the xformer is placed directly across the battery.. with the circuit breaker inline. If a diode in a FWB circuit shorts, then 1 half the sinwave will be opposite polarity with the battery.. ALSO inline with the circuit breaker.
draw the schematic out.. the DC side is taking the hit.. and that dc side is a straight piece of wire running continously thru the xformer secondary.. ALL series with the circuit breaker.. with the battery as part of the circuit.
soundguy
Even in a very old simple Sears chgr that I autopsied, they had the bases pretty well covered. For load side simple overloads, reverse connection to battery, diode short or whatever, the re-setting device functions. For secondary winding shorts, whether it be diode or turn to turn winding failure and primary winding failure, the input thermal fuse buried in windings functions.
third party image
Diodes: In my 30 years designing, building, analyzing failures in power supplies from ma/volts to 1000amp/KVolts, I learned (by the bucket full of blown parts) that diodes almost alway first exhibit a short as they fail, THEN....if the source is low power, it remains a short, BUT if the source has sufficient power, the junction, bond wire, even the case itself is burned until the circuit opens. It would require a locomotive sized diode to stand shorted across an automotive/tractor battery and not open, assuming the connecting wiring doesn't burn open first. To witness the current available first hand so to speak, just brand you hands by holding a coat hanger across your battery terminals! It won't take you long to feel that coat hanger! Now that last part didn't come from 30 years experience....came from hunting thru Dad's wrecking yard for hot batteries at about age 8. Brother got a big laugh :), but I didn't. :(
mad farmer
01-17-2008 12:31:06
 Re: Trickle charger for 6 volt batteries in reply to Britcheflee, 01-16-2008 15:36:47
If the tractor is outside or near a sunny window another option is a 6V solar charger. No outlet needed and won't overcharge either.
JMOR
01-17-2008 08:47:52
 Re: Trickle charger for 6 volt batteries in reply to Sean (TX), 01-16-2008 15:36:47
Jack, the Float/maintainer devices are low power and are not intended to run loads, just maintain a battery (cover battery internal losses). Usually rated at less than one amp. Battery manufacturers recommend "maintaining" at less than "end-of-charge" voltage, generally 2.2 per cell or 13.2v on 12v batteries, so your measured numbers look right, depending on temperature, equipment accuracy and such variables.
You motor home folks, boaters, snowmobilers, cyclist are usually the most aware bunch when it comes to maintaining batteries.
jon
01-17-2008 08:34:59
 Re: Trickle charger for 6 volt batteries in reply to Jim SC, 01-16-2008 15:36:47
Dell (WA) said: (quoted from post at 12:31:33 01/17/08) Jon..... ..electrons don't care, red or black, positive or negative ground. Infact chassis ground can be positive and negative at the same time. Isn't that confusing???
Yer chemical battery cares that the charger RED plus (+) clippie connects to the battery PLUS (+) terminal and the charger BLACK minus (-) clippie connects to the battery MINUS (-) terminal.
And NO, you do NOT haffta disconnect enny of yer battery cables from the battery, just klip the charger connections to the correct battery studs. Isn't that simple, eh?..... ...Dell
Thank you Dell. It was just the neg ground part that was confusing me. Just didn't seem right to hook a pos clip to a terminal that grounded to the tractor!
JMOR
01-17-2008 07:59:06
Pardon my nose, but it seems no one addresses the real difference among some of these charging /charger arrangements in the two recent "trickle" & "float" threads.
The 'wall-wart', standard simple battery chargers, dc source with a resistor, etc. will all 'trickle' a current into the battery as long as connected to power & a battery. If remains connected forever, that battery will be over-charged, out gas, boil away the electrolyte. This is not good. A timer is a step to correct this problem & if you manage to get the time right (exactly in balance with the 'battery idle' internal losses) it is a perfect solution.
Those more expensive FLOAT chargers have regulator circuits in them to act just as the regulator's function with your generator or alternator. It will supply current to the battery when needed & no current when not needed, so as to maintain a fully charged state. Will not over-charge the battery. You recall the often quoted numbers in the alt/gen/reg threads of 14.2 to 14.6v and 7.1 to 7.3v? Those are set to those values because the 'end of charge' voltage for a fully charged lead acid battery is 2.4volts per cell (14.4 and 7.2). A Float charger will cycle current flow on/off as the battery voltage drops below or rises above those values. To really get to the nat's hair of things, the batteries 2.4v per cell voltage varies with temperature & the 'really good' FLOAT chargers even take temperature into account and adjust accordingly.
Finally, despite all this seeming complexity, even the el-cheapo Harbor Tool Float charger that looks like a 'wall-wart' with a another 1/2 'cigarette sized' box mid-way in the cord, has a pretty good regulator inside! You can leave it on forever and on sale regularly for $10. I have no connection with Harbor Tool, except that they do from time to time collect and send some of my hard earned cash to China. And I apologize for that. America, make me one for $10!
Jack - Illinois
01-17-2008 08:30:32
 Re: Trickle charger for 6 volt batteries in reply to JMOR, 01-17-2008 07:59:06
JMOR - I agree - I had trouble with our motor home maintaining the coach battery and the chassis battery. (The problem with the origianl system is that the solenoid that ties the batteries together to charge is not making contact through it when energized). I am temporarily running the motorhome's converter on the coach battery and a Harbor Freight 12 volt battery maintainer on the chassis battery. They have been in 1/10 of a volt of each other every time I have checked them. Voltage has been 13.5 or 13.6 on all checks. Point is - The Harbor Freight maintainer that I got for $4.99 on sale is holding the battery voltage as well as the over $300 converter. The maintainer however will not pick up the load of 12 volt lights, furnace, refrigerator and gas and carbon monoxide detectors that could be on the coach battery. I too have no connection with Harbor Freight and only mean this to tell what results I got on my own test. - Jack
jon
01-17-2008 07:38:48
 Re: Trickle charger for 6 volt batteries in reply to Andrew Matushek, 01-16-2008 15:36:47
Jeff-oh said: (quoted from post at 10:03:12 01/17/08) If your interested in the Harbor Freight charger shown. Be sure to buy it on a sale. It seems to go on sale every 2 to 3 weeks.
Jeff
I got the one that was $29.99 just because it had a little higher amp setting for 6 volt plus boost for 12volt. Seems to do ok. It has a green light showing when battery is charged so it might be safe to leave it hooked up all the time. I need to read up on that tho to be sure.
jeff-oh
01-17-2008 13:06:18
 Re: Trickle charger for 6 volt batteries in reply to jon, 01-17-2008 07:38:48
I think even that one goes on sale at times.
jon
01-17-2008 07:35:14
Another 6 volt pos ground question I can never remember....
When charging/maintaining the battery while in the tractor, with the terminals connected to starter-ground, which post does the Red (+) alligator clip on the charger go to? Pos to the charger or whats pos to the battery? That make sense?
Jeff-oh
01-17-2008 13:05:42
 Re: Trickle charger for 6 volt batteries in reply to jon, 01-17-2008 07:35:14
Always + to + and - to -. If you start to hook it up wrong you be told about it right now as the thing arcs and goes pop.
Dell (WA)
01-17-2008 08:31:33
souNdguy
01-17-2008 05:55:00
As the others siad.. yes.. it will keep the battery up.. but plenty of lower $$ options exist. napa still makes a 1.5A 12v/6v charger.. etc.
the chinese charger should work OK as well. ( if it works out of the box! )
soundguy
36 coupe
01-18-2008 02:05:30
 Re: Trickle charger for 6 volt batteries in reply to souNdguy, 01-17-2008 05:55:00
I find it a bit strange that so many will risk expensive equipment by putting a 5.00 wall wart on it .They will melt down if a diode shorts.
soundguy
01-18-2008 11:31:46
 Re: Trickle charger for 6 volt batteries in reply to 36 coupe, 01-18-2008 02:05:30
In small equipment like those wall warts, the overwhelming fault that occurs with the diodes are opens... not shorts.
If a diode did short.. the battery would QUICKLY burn out those hair thin windings in the secondary if there was any juice inthe battery at all.
besides... have you ever opened up a standard plain battery charger/booster from any of the box stores.. if you had, you'd find a transformer, a rectifier or bridge, a switch if it is a dual voltage or dual current model, and a circuit breaker... and that's about it.... prety much the same as the 5$ wall wart.. just more current capacity.
soundguy
soundguy
3 6 coupe
01-18-2008 14:26:27
 Re: Trickle charger for 6 volt batteries in reply to soundguy, 01-18-2008 11:31:46
I repair battery chargers.I have a bad wall wart that powered a cordless phone base.It melted, got very hot before the winding opened.The circuit breaker in a common charger wont protect the transformer if a diode shorts.late chargers have a thermal fuse buried in the winding.If that opens the transformer is worthless.I have seen flames coming out of the top of a 6a charger.Always find shorted diodes in chargers.The old selenium rectifiers just got weak.
soundguy
01-18-2008 20:52:40
 Re: Trickle charger for 6 volt batteries in reply to 3 6 coupe, 01-18-2008 14:26:27
Selenium rectifiers are yesterdays technology. i thought we were talking about todays technology.. IE.. the wall warts.
which one you want to talk about. Most wall warts i see have silicon based diodes.. and rarely.. germanium.
The circuit breaker inthe secondary of a charger circuit can and will open if it's current capacity threshold is breached. if a diode shorted and let an ac wave.. ie reverse current in.. I'm betting there is going to be sufficient current to pop that breaker.. if not.. it's -a -VERY- poor circuit design... The circuit breaker should be sized for the max charge rate on the charger plus a small tolerance... not much more..
soundguy
36coupe
01-19-2008 02:21:12
 Re: Trickle charger for 6 volt batteries in reply to soundguy, 01-18-2008 20:52:40
Take a look at a battery charger.The circuit breaker is in the DC output.Shorted diodes place a dead short across the trans formers secondary.The transformer will burn before the line fuse or line circuit breaker opens.The circuit breaker in the charger only opens when the charger leads are reversed on a battery.My chargers have a 5a fuse in the primary.
soundguy
01-21-2008 05:02:31
 Re: Trickle charger for 6 volt batteries in reply to 36coupe, 01-19-2008 02:21:12
soundguy
36coupe
01-22-2008 16:48:35
 Re: Trickle charger for 6 volt batteries in reply to soundguy, 01-21-2008 05:02:31
You are 1 brick short of a load.Fire will result..
soundguy
01-23-2008 05:19:59
 Re: Trickle charger for 6 volt batteries in reply to 36coupe, 01-22-2008 16:48:35
You just like to argue and don't have a full grasp of electrical theory.. or at least not enough to put up a good argument than to claim fire.
DC power supplies and chargers are the 2nd most simple circuit there is to build.. with a lamp circuit being the easiest.
I've witnessed plenty of failures of power supply and charger circuits from transformer primary and secondary failures, both in fused / breaker or unprotected circumstances. Worst I have ever seen is some magic smoke escaping after a thermal overload in the xformer.
I'f I'm one brick short.. you are missing the entire building.
Pick someone else to argue with.. Perhaps someone who doesn;'t know electrical theory so you can buffalo them... This isn't nuclear physcs.. it's 58 year old solid state silicon junction diode technology..
soundguy
Too Tall
01-17-2008 05:22:49
As stated above, it will work.
However - someone is making a lot of $ on that charger!
I'd go with something like this (set on low) on a timer set to charge 30-60 minutes a day. It'll do what you need, save you some $, and be usefull for your cars and other toys, err, tools too. The one you linked to above will only do one thing...
Link
third party image
Jeff-oh
01-17-2008 06:03:12
 Re: Trickle charger for 6 volt batteries in reply to Too Tall, 01-17-2008 05:22:49
Jeff
Jeff-oh
01-17-2008 06:04:09
 Re: Trickle charger for 6 volt batteries in reply to Jeff-oh, 01-17-2008 06:03:12
BTW I do have that same model and I am happy with it... Ran something like $16 or so with the e-mail promotion coupons they send out.
Jack - Illinois
01-16-2008 18:28:55
Yep it will work, but kind of pricey! If you have a 6 volt charger that will charge at about 2 amps, hook it to a wall plug in timer and set the pins on the timer to charge a half hour or so every day. That would do the same trick for about $5
MikeT
01-16-2008 18:26:51
Lee -
What I do is plug my 12V charger into a 24 hr light timer set to only come on 1 hr per day. After setting unused for 3 months last winter the tractor fired right up (6-cyl Funk with 12V battery). Doing the same thing this winter. Hopefully your charger has a 6V setting?
By the way, if anyone else gets one of those little 'automatic' chargers, make sure that you don't have to punch a button on it to get it to come back on after a power failure.
JohnK-NJ
01-16-2008 17:47:16
I put one on my 6V back in November... I'll let you know in April, when I get back there, if it worked. If it is any indication the same unit, but 12V, is working fine on my lawn mower.
You might save a buck or two at
Link
Den N Ms
01-16-2008 17:01:23
Britcheflee, Look down a couple post ,an old 6 volt charger 500 ma that you might have layin around from light,old cell phone drill ect will keep your battery charged up.I keep one on my gen set all the time.
Bob
01-16-2008 15:44:24
Looks good to me.
